[Qgis-psc] QGIS-Hub proposal
Klas Karlsson
klas.karlsson at geosupportsystem.se
Thu Aug 6 04:35:36 PDT 2020
Hi
My name is Klas Karlsson and I dabble with QGIS in my spare time, and
once in a while I get an idea...
# Proposal to implement a "QGIS Hub" on the official qgis.org site.
## Background
I was creating a lot of styles just for fun, and was thinking about
creating a PR to the QGIS GitHub.
However, a lot of the styles were really intricate and might apply to
relatively few use cases.
In stead of filling up the default styles with nice but really
"un-expandable" styles, there should be
an easier way.
Sure, there's the resource sharing plugin, and it works great. But it is
a lot of steps to go through
for someone that is only interested in sharing a simple style or two.
Enter the idea of a "style hub".
On https://style-hub.github.io I created a demo of how it could look. I
also created https://layout-hub.github.io
and that made me realize that there may be a few of these simpler
resource files that the community
would like to share, but don't because of the complexity to do so.
## QGIS Hub
So why not at central "Hub" for all kinds of small and easy to share
resources?
On https://github.com/style-hub/hub-server/ I started a project to
create such a hub.
During the development so far I've used local servers to test it, but to
get some feed-back
I also set up a site on free hosting at http://qgis-hub.rf.gd, which
isn't great since it for instance lack
TLS/SSL, which is required for some functions, but it should be enough
to get some user reactions.
The goal is to create the style-hub first, and then use that to "clone"
it to a layout-hub too.
I'm doing this because it's fun and educational, but if it gets approval
it would probably look good at:
__hub.qgis.org__
## Requirements
The code is available at GitHub and basically the requirements are:
* PHP web hosting
* MySQL database (users and meta data)
* TLS/SSL for https (required for some functions)
* Storage space for resource files (write access) (1 Gb will probably
store well over 1'000 resources)
I'm willing to continue to work on the site, but I would prefer not to
do so alone, since I don't
have the time to drop everything if there's a problem (as mentioned in
the beginning I'm doing this in my
spare time).
My skills at PHP and MySQL is also limited (this is a learning experience),
so the code would probably benefit from some audit, and if the hub is to
be included in the official site
I guess it should be styled in the same way, which also would require
some work.
For now I will continue to work on the site at http://qgis-hub.rf.gd as
long as I think it is still fun
and I have time available.
Best regards
Klas Karlsson
Mail: klas.karlsson at geosupportsystem.se
Twitter: @klaskarlsson
YouTube: https://youtube.com/klaskarlsson
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200806/8a026b7f/attachment.html>
More information about the Qgis-psc
