[Qgis-psc] [QGIS-Developer] Documentation bot
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Jan 6 21:11:50 PST 2020
Le lun. 6 janv. 2020 à 18:47, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> Hi Denis,
> Thanks this sounds much better than the previous solution.
> Was the older bot deactivated? The one that creates tickets by commit with
> the need-docs tag?
No, not yet. I wouldn't know where to deactivate it neither have access to
it.
> This means devs should no longer add the need-docs tag in individual
> commits?
Following the next discussion from Nyall, this could be complementary.
> Thanks,
> Alexandre Neto
> A segunda, 6/01/2020, 12:57, Denis Rouzaud <denis.rouzaud at gmail.com>
> escreveu:
>> Dear Devs,
>> This is a report for the QGIS grant proposal to create a documentation
>> bot.
>> This bot is now alive and automatically create an issue in the
>> documentation repo for merged PR.
>> ** How to use it **
>> 1) Create a PR on qgis/QGIS
>> 2) tag it with "Needs Documentation"
>> 3) optionally set the milestone to it
>> 4) merge it
>> => an issue is automatically created in the qgis/QGIS-Documentation
>> repository
>> => you get a message telling you should take care of it
>> Example:
>> dummy PR: https://github.com/qgis/QGIS/pull/33627
>> created issue: https://github.com/qgis/QGIS-Documentation/issues/4744
>> I have left some notes next to the action, explaining how it works
>> https://github.com/qgis/QGIS/blob/master/.github/workflows/pr_to_doc_issue.md
>> Thanks to the community and QGIS.org for sponsoring this feature.
>> Best wishes,
>> Denis
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200107/ff748264/attachment.html>
More information about the Qgis-psc
