[Qgis-psc] doc-test repo
Marco Bernasocchi
marco at qgis.org
Tue Jun 9 00:59:28 PDT 2020
Hi Harrissou,
Matthias told me that the problem is solved by having admin (maybe even
maintain) permission on the repo, surprisingly to me you were not in
the documentation-admins group which you should now be.
Let me know if the problem is fixed.
Ciao
Marco
On 08.06.20 22:27, DelazJ wrote:
> Hi Marco & all,
> Le jeu. 4 juin 2020 à 17:36, Marco Bernasocchi <marco at qgis.org
> <mailto:marco at qgis.org>> a écrit :
> Thanks Alessandro,
> Richard, it is because I removed what Github considers legacy
> permissions [1]
> Could that also be the reason why I can't find the button to restart
> qgis/QGIS-Documentation travis build when I'm connected? It used to
> work (was still there last wednesday - I used it intensively when the
> doc test was continuously failing). Now I can only watch the repo, no
> way to interact and see config. Not that I need it right now but as I
> remarked...
> Or is it a separate issue (I remember Matthias or Martin(?) recently
> had an issue with access to QGIS travis build repo)?
> Greetings,
> Harrissou
> Cheers
> Marco
> https://help.github.com/en/github/setting-up-and-managing-organizations-and-teams/migrating-admin-teams-to-improved-organization-permissions
> On 04.06.20 17:02, Alessandro Pasotti wrote:
> > done
> > On Thu, Jun 4, 2020 at 4:55 PM Richard Duivenvoorde
> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
> >> Hi PSC,
> >> I am not able to create repo's in QGIS organisation anymore?
> >> Are permissions changed? Or do I miss a button :-)
> >> Can somebody please create a repo called 'doc-test' so
> Harrissou and me
> >> can try out some automated transifex-github linking?
> >> Regards,
> >> _______________________________________________
> >> Qgis-psc mailing list
> >> Qgis-psc at lists.osgeo.org <mailto:Qgis-psc at lists.osgeo.org>
> >> https://lists.osgeo.org/mailman/listinfo/qgis-psc
> Marco Bernasocchi
> QGIS.org Chair
> http://berna.io
Marco Bernasocchi
QGIS.org Chair
http://berna.io
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200609/f6bf5797/attachment.html>
More information about the Qgis-psc
