[Qgis-psc] doc-test repo
DelazJ delazj at gmail.com
Wed Jun 10 00:39:09 PDT 2020
Hi Marco,
No, it does not solve. And it would indeed be weird that a change done mid
may would be the (direct) trigger of my loss this week.
Giving it a closer look, I also lost reference to the qgis/QGIS repo I had
added to travis. And clicking the + button to add more repositories only
offers selection among my own repos/forks. Not the ones of QGIS.
So I'm not sure it has anything to do with my privileges in QGIS github
repo, but something to do with travis itself (I can see qgis organisation
listed in the settings, with everything green!).
Anyway, thanks for having tried to help me out. Maybe it will resurrect one
day. Hope that I don't need it in the meantime.
Regards,
Harrissou
Le mar. 9 juin 2020 à 10:00, Marco Bernasocchi <marco at qgis.org> a écrit :
> Hi Harrissou,
> Matthias told me that the problem is solved by having admin (maybe even
> maintain) permission on the repo, surprisingly to  me you were not in the
> documentation-admins group which you should now be.
> Let me know if the problem is fixed.
> Ciao
> Marco
> On 08.06.20 22:27, DelazJ wrote:
> Hi Marco & all,
> Le jeu. 4 juin 2020 à 17:36, Marco Bernasocchi <marco at qgis.org> a écrit :
>> Thanks Alessandro,
>> Richard, it is because I removed what Github considers legacy
>> permissions [1]
>> Could that also be the reason why I can't find the button to restart
> qgis/QGIS-Documentation travis build when I'm connected? It used to work
> (was still there last wednesday - I used it intensively when the doc test
> was continuously failing). Now I can only watch the repo, no way to
> interact and see config. Not that I need it right now but as I remarked...
> Or is it a separate issue (I remember Matthias or Martin(?) recently had
> an issue with access to QGIS travis build repo)?
> Greetings,
> Harrissou
>> Cheers
>> Marco
>> https://help.github.com/en/github/setting-up-and-managing-organizations-and-teams/migrating-admin-teams-to-improved-organization-permissions
>> On 04.06.20 17:02, Alessandro Pasotti wrote:
>> > done
>> > On Thu, Jun 4, 2020 at 4:55 PM Richard Duivenvoorde <
>> rdmailings at duif.net> wrote:
>> >> Hi PSC,
>> >> I am not able to create repo's in QGIS organisation anymore?
>> >> Are permissions changed? Or do I miss a button :-)
>> >> Can somebody please create a repo called 'doc-test' so Harrissou and me
>> >> can try out some automated transifex-github linking?
>> >> Regards,
>> >> _______________________________________________
>> >> Qgis-psc mailing list
>> >> Qgis-psc at lists.osgeo.org
>> >> https://lists.osgeo.org/mailman/listinfo/qgis-psc
>> Marco Bernasocchi
>> QGIS.org Chair
>> http://berna.io
> Marco Bernasocchi
> QGIS.org Chairhttp://berna.io
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200610/e63b148c/attachment.html>
More information about the Qgis-psc mailing list
