[Qgis-psc] PyQgis Cookbook revision
Paolo Cavallini cavallini at faunalia.it
Sun Mar 1 10:18:06 PST 2020
Thanks Ale.
On 1 March 2020 18:32:46 CET, Alessandro Pasotti <apasotti at gmail.com> wrote:
>On Sun, Mar 1, 2020 at 1:13 PM Paolo Cavallini <cavallini at faunalia.it>
>wrote:
>> Hi Harrissou,
>> I think everybody agrees in improving documentation, both for devs
>and
>> for users. Could you ask the proponents to put a formal proposal for
>> funding?
>The proponents is me, here is my proposal about the cookbook contents
>revision (basically copied from my original email):
>make a revision of the current cookbook text and code snippets in order
>to:
>- update the text and the code snippets
>- put ALL code snippets under the existing automated Python test CI
>infrastructure.
>The current situation (well, current when I wrote the original email
>but I don't think it has changed):
>- python code samples/snippets: 202
>- python code samples/snippets currently tested: 53
>My plan is:
>1. check all the cookbook text for 3.10 (or whatever the LTR will be
>when I will do the work) API changes and update it accordingly
>2. put the 149 untested snippets under test
>As far as point 1 is concerned the following files have the
>'outofdate' directive:
>./source/docs/pyqgis_developer_cookbook/server.rst
>./source/docs/pyqgis_developer_cookbook/settings.rst
>./source/docs/pyqgis_developer_cookbook/network_analysis.rst
>./source/docs/pyqgis_developer_cookbook/canvas.rst
>./source/docs/pyqgis_developer_cookbook/authentication.rst
>./source/docs/pyqgis_developer_cookbook/plugins/ide_debugging.rst
>./source/docs/pyqgis_developer_cookbook/plugins/pluginlayer.rst
>./source/docs/pyqgis_developer_cookbook/plugins/releasing.rst
>./source/docs/pyqgis_developer_cookbook/raster.rst
>this of course doesn't mean that all others are necessarily uptodate,
>but we can assume that they require less work to be updated.
>It's a bit difficult to estimate the exact amount of work required to
>achieve
>both tasks, especially because some code samples will require quite a
>lot
>of setup and data in order to run in the automatic tests.
>However, I think the most efficient way to proceed is to work on both
>tasks simultaneously: while checking the code samples it will be easier
>to also apply corrections to the text.
>Total time required: 5 days at the standard QGIS hourly rate.
>Note that in the original thread was discussed to move the cookbook
>outside of the documentation, but that task is completely independent
>from the text and code revision and it is not included in my proposal.
>Regards.
>Alessandro Pasotti
>w3:   www.itopen.it
Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200301/ccc7cf40/attachment.html>
More information about the Qgis-psc mailing list
