[Qgis-psc] PyQgis Cookbook revision
Paolo Cavallini
cavallini at faunalia.it
Wed Mar 18 03:08:58 PDT 2020
Hi all,
any news on this? It seems a good idea, and I didn't see any objection.
Should we vote on the proposal?
Cheers.
Il 01/03/20 18:32, Alessandro Pasotti ha scritto:
> On Sun, Mar 1, 2020 at 1:13 PM Paolo Cavallini <cavallini at faunalia.it> wrote:
>> Hi Harrissou,
>> I think everybody agrees in improving documentation, both for devs and
>> for users. Could you ask the proponents to put a formal proposal for
>> funding?
> The proponents is me, here is my proposal about the cookbook contents
> revision (basically copied from my original email):
> make a revision of the current cookbook text and code snippets in order to:
> - update the text and the code snippets
> - put ALL code snippets under the existing automated Python test CI
> infrastructure.
> The current situation (well, current when I wrote the original email
> but I don't think it has changed):
> - python code samples/snippets: 202
> - python code samples/snippets currently tested: 53
> My plan is:
> 1. check all the cookbook text for 3.10 (or whatever the LTR will be
> when I will do the work) API changes and update it accordingly
> 2. put the 149 untested snippets under test
> As far as point 1 is concerned the following files have the
> 'outofdate' directive:
> ./source/docs/pyqgis_developer_cookbook/server.rst
> ./source/docs/pyqgis_developer_cookbook/settings.rst
> ./source/docs/pyqgis_developer_cookbook/network_analysis.rst
> ./source/docs/pyqgis_developer_cookbook/canvas.rst
> ./source/docs/pyqgis_developer_cookbook/authentication.rst
> ./source/docs/pyqgis_developer_cookbook/plugins/ide_debugging.rst
> ./source/docs/pyqgis_developer_cookbook/plugins/pluginlayer.rst
> ./source/docs/pyqgis_developer_cookbook/plugins/releasing.rst
> ./source/docs/pyqgis_developer_cookbook/raster.rst
> this of course doesn't mean that all others are necessarily uptodate,
> but we can assume that they require less work to be updated.
> It's a bit difficult to estimate the exact amount of work required to achieve
> both tasks, especially because some code samples will require quite a lot
> of setup and data in order to run in the automatic tests.
> However, I think the most efficient way to proceed is to work on both
> tasks simultaneously: while checking the code samples it will be easier
> to also apply corrections to the text.
> Total time required: 5 days at the standard QGIS hourly rate.
> Note that in the original thread was discussed to move the cookbook
> outside of the documentation, but that task is completely independent
> from the text and code revision and it is not included in my proposal.
> Regards.
> Alessandro Pasotti
> w3: www.itopen.it
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
More information about the Qgis-psc
