[Qgis-psc] PyQgis Cookbook revision
Richard Duivenvoorde
rdmailings at duif.net
Thu Mar 19 02:39:29 PDT 2020
On 3/19/20 10:34 AM, Alessandro Pasotti wrote:
> The main goal is to put code snippets under CI test and to make the
> tests pass, secondary goal it to update the text content to reflect
> changes in the API when necessary.
Hi Alessandro, just to be sure: If I'm correct the code snippets are
already under CI test now isn't it?
Arnaud created this during a hackfest.
If you use the new build structure of the docs and use 'make doctest',
then you will have a venv and run the doctests with the qgis/qgis docker.
But you probably already knew, just wanted to be sure.
Regards,
PS if not, just contact me...
More information about the Qgis-psc
