[Qgis-psc] QGIS bug-fixing efforts - work on upstream libraries (specifically GEOS)
Alessandro Pasotti
apasotti at gmail.com
Fri Sep 18 02:22:08 PDT 2020
+1 for GEOS bug fixing.
On Thu, Sep 17, 2020 at 3:51 PM Andreas Neumann <andreas at qgis.org> wrote:
> Now the list is public:
> > Things that we would like to see addressed are e.g. the following:
> > - in general things in geos trac that reads "doesn't give expected results"
> > - more specifically
> > * https://trac.osgeo.org/geos/ticket/984
> > * https://trac.osgeo.org/geos/ticket/980
> > * https://trac.osgeo.org/geos/ticket/979
> > * https://trac.osgeo.org/geos/ticket/960
> > Other improvements would be around performance in GEOS, e.g.
> > - https://trac.osgeo.org/geos/ticket/1007
> However, strk suggests to first finish the OverlayNG GEOS effort and then see how this affects the above mentioned tickets - it might have changed things a bit and maybe some of the above mentioned tickets are already fixed with the OverlayNG GEOS work.
> Thanks,
> Andreas
> On Thu, 17 Sep 2020 at 15:46, Jürgen E. Fischer <jef at norbit.de> wrote:
>> Hi Andreas,
>> On Thu, 17. Sep 2020 at 13:20:04 +0200, Andreas Neumann wrote:
>> > I'd like to ask for permission that strk could work on GEOS issues on
>> > behalf of the QGIS bug fixing effort, in a similar manner like Even often
>> > fixes issues in GDAL/OGR when fixing issues in QGIS.
>> +1
>> > Specifically, Nyall sent me a list of GEOS issues that he'd like to see
>> > addressed - also we would need some z-handling improvements in the
>> > OverlayNG GEOS effort.
>> Is that list public somewhere?
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>> Software Engineer D-26506 Norden https://www.norbit.de
>> QGIS release manager (PSC) Germany IRC: jef on FreeNode
>> Qgis-psc mailing list
>> Qgis-psc at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
> Andreas Neumann
> QGIS.ORG board member (treasurer)
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
More information about the Qgis-psc
