[Qgis-psc] [QGIS-Developer] (QGIS 2020 Grant Report) Use of FileGeodatabase spatial index in OpenFileGDB driver
Tim Sutton tim at kartoza.com
Mon Sep 28 15:14:51 PDT 2020
Wow, thank you for the update, great work!
@Andreas do you think it would be possible to accummulate the paid bugfix
and grant work in the changelog a week or so before we release?  We want to
try for the first time to have the visual changelog go out at the same time
as the release...
Regards
Tim
On Mon, 28 Sep 2020, 21:29 Even Rouault, <even.rouault at spatialys.com> wrote:
> Hi,
> I want to report about the outcome of
> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/172
> "Use of FileGeodatabase spatial index in OpenFileGDB driver"
> This work has been successfully completed into GDAL master (for upcoming
> GDAL 3.2) per https://github.com/OSGeo/gdal/pull/2771 , and automatically
> benefits to QGIS when it uses the OpenFileGDB driver.
> Some figures on a version from of few years ago of the dataset at
> https://data.linz.govt.nz/layer/50772-nz-primary-parcels/, featuring 2
> 484 646 polygons, 773 MB:
> "ogrinfo -spat 174.949909 -41.143842 175.684529 -40.594600 -al -so
> -noextent" (thus counting the number of features intersecting the spatial
> filter), which returns 81 046 polygons, nows runs in 400 ms with GDAL
> 3.2dev and the OpenFileGDB driver, versus 6.7 s before (full scan), vs 890
> ms with the FileGDB driver (with FileGDB SDK 1.5).
> All figures given with debug builds, and on a hot run (so with most pages
> cached by the OS).
> Interactive display of this dataset in QGIS with the OpenFileGDB driver is
> as fluid as with the FileGDB one. Comparing behaviour of OpenFileGDB and
> FileGDB drivers with strace shows that they read a similar amount of data
> in the .spx file, which confirms it is uses correctly.
> The filegdb reverse engineered specification was also updated in
> https://github.com/rouault/dump_gdbtable/wiki/FGDB-Spec#specification-of-spx-files
> Thanks to qgis.org grant program for making this improvement possible.
> Best regards,
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200928/ac79ce5d/attachment.html>
More information about the Qgis-psc mailing list
