[Qgis-psc] Grant voting 2021 closed
Anita Graser
anitagraser at gmx.at
Fri Apr 23 10:30:28 PDT 2021
Dear PSC members,
Voting has closed now. You can find the voting responses here:
https://docs.google.com/spreadsheets/d/1khDRDElKTnB6e_p_ptUz4-4735RCOa7UZfh3hEsQrjI/edit?usp=sharing
I received one change request via email that is reflected in the second
sheet.
I've also spotted one issue of two votes cast by the same country user
group representative. I've fixed that in the second sheet as well.
The third sheet follows the process as outlined in our grant programme
process document:
The calculation of votes is done by summing up the votes. We will then
calculate the total number of points that each proposal scores and rank
them accordingly.
Grants will be approved by working sequentially from top scoring
proposal to lowest until all the funds have been allocated. If the top
candidates do not exactly coincide with the total grant budget, we may,
depending on available funds, ‘top up’ the grant budget to include the
next-in-line proposal and use up all of the available funds.
The computed results should be reviewed and confirmed by at least two
PSC members before publishing the results.
So please have a look and review my results.
Regards,
Anita
More information about the Qgis-psc
