[Qgis-psc] QGIS LTR releases -- is it time to pull the plug?
Jürgen E. Fischer
jef at norbit.de
Tue Nov 16 00:59:35 PST 2021
On Tue, 16. Nov 2021 at 05:57:09 +1000, Nyall Dawson wrote:
> I'd like to start some conversation about the dire condition of the
> QGIS LTR release and what we can do to remedy/avoid this in future.
> If you've missed the conversation, our QGIS 3.16 windows releases have
> been completely broken for nearly a month now. 3.16.12 had a critical
> issue which caused lockups in Python code, and now 3.16.13 has
> completely broken projection handling (resulting in loss of CRS,
> hangups when opening projects, etc).
Only the 3.16.13 MSI is broken (not sure if 3.16.12-2 is affected). OSGeo4W
v2 was meanwhile fixed. All other platforms are not affected at all. The
next release is on friday and will also produce a fresh MSI.
I 'downgraded' the website to 3.16.11 and the website rebuild is ongoing.
Doing another MSI of 3.16.13 would be an option, but I guess as the 3.16.14 is
due on friday - it's probably good enough to just do that and sort it out
that way.
bbl. Heading to the office now…
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20211116/19346037/attachment-0001.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20211116/19346037/attachment-0001.ksh>
More information about the Qgis-psc
