[Qgis-psc] First sample outputs of telemtry work
Régis Haubourg
regis.haubourg at gmail.com
Fri Apr 29 07:57:26 PDT 2022
Hi Tim,
the results are mind blowing !
Really nice work. More than 50K openings every day is huge.
I'm not sure I understand correctly the "other" category in the per-country
graph. Is it the sum of all calls?
I would like to be sure to correctly interpret the fact that French users
are probably ~45% of the total users. (which does not surprise me, still we
are far away from contributing financially at the level of usage)
Best regards
Régis
Le ven. 29 avr. 2022 à 15:57, Tim Sutton <tim at kartoza.com> a écrit :
> Hi PSC
> I just wanted to give you some feedback on the work we have been doing to
> use anonymised telemetry data from the feed to try to get a handle on the
> number, geography and platform choice of our user base. There are detailed
> notes in the image below which should explain things. Currently it has only
> been running about 2 weeks so the year and month charts at the end look the
> same, but you can expect these to diverge over time.
> If you have other things you would like to report on with the available
> data, please pop me a note. I still want to aggregate the platform better
> to lump together Win, Mac, Linux and other instead of the more granular
> breakdown we get right now. I will do so when I get a chance.
> I do not plan to make the link to the live dashboard public as I don't
> want to put load on the feed server, but if you wish to access the
> dashboard, pop me a note and I will add you.
> https://user-images.githubusercontent.com/178003/165956926-a30c6c96-3b6b-4895-8afb-97e9ba0bd28c.png
> Regards
> Tim
> Tim Sutton
> Visit http://kartoza.com to find out about open source:
> * Desktop GIS programming services
> * Geospatial web development
> * GIS Training
> * Consulting Services
> Tim is a member of the QGIS Project Steering Committee
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20220429/ce78976d/attachment.html>
More information about the Qgis-psc
