[Qgis-psc] First sample outputs of telemtry work
    Tim Sutton
    tim at kartoza.com
    Fri Apr 29 14:28:24 PDT 2022
Hi Regis
On Fri, Apr 29, 2022 at 3:58 PM Régis Haubourg <regis.haubourg at gmail.com>
wrote:
> Hi Tim,
> the results are mind blowing !
> Really nice work. More than 50K openings every day is huge.
500k ! :-)
> I'm not sure I understand correctly the "other" category in the
> per-country graph. Is it the sum of all calls?
> I would like to be sure to correctly interpret the fact that French users
> are probably ~45% of the total users. (which does not surprise me, still we
> are far away from contributing financially at the level of usage)
Probably you should take a look at the walk through I did in the open day
(starting around 6 minutes in)
https://www.youtube.com/watch?v=30BQb5cEwgY
So reading your and Andreas's questions / comments makes it obvious to me
that I need to share the actual dashboard, not an image of it since you
lose a lot of context by not being able to hover over the information icons
and see the tooltips. So here we go:
http://feed.qgis.org/metabase/public/dashboard/df81071d-4c75-45b8-a698-97b8649d7228
Note if it degrades the performance of the news feed, I will unpublish it
again from public access.
In the case of the French numbers you are seeing, this is not the brute
user base rather it reflects that accumulation of new users each day
compared to the previous daily average for that country. i.e. it is showing
'growing' user base countries.
For the other categories they bundle classes after the first X
significant classes.
Hope that helps to make sense of things a bit. This is definately just a
first prototype and I will be more than happy to share access to anyone who
wants to help improve the dashboard and also check my query logic.
Regards
Tim
> Best regards
> Régis
> Le ven. 29 avr. 2022 à 15:57, Tim Sutton <tim at kartoza.com> a écrit :
>> Hi PSC
>> I just wanted to give you some feedback on the work we have been doing to
>> use anonymised telemetry data from the feed to try to get a handle on the
>> number, geography and platform choice of our user base. There are detailed
>> notes in the image below which should explain things. Currently it has only
>> been running about 2 weeks so the year and month charts at the end look the
>> same, but you can expect these to diverge over time.
>> If you have other things you would like to report on with the available
>> data, please pop me a note. I still want to aggregate the platform  better
>> to lump together Win, Mac, Linux and other instead of the more granular
>> breakdown we get right now. I will do so when I get a chance.
>> I do not plan to make the link to the live dashboard public as I don't
>> want to put load on the feed server, but if you wish to access the
>> dashboard, pop me a note and I will add you.
>> https://user-images.githubusercontent.com/178003/165956926-a30c6c96-3b6b-4895-8afb-97e9ba0bd28c.png
>> Regards
>> Tim
>> Tim Sutton
>> Visit http://kartoza.com to find out about open source:
>>  * Desktop GIS programming services
>>  * Geospatial web development
>> * GIS Training
>> * Consulting Services
>> Tim is a member of the QGIS Project Steering Committee
>> Qgis-psc mailing list
>> Qgis-psc at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20220429/e7d1a867/attachment.html>
More information about the Qgis-psc
