[Qgis-psc] First sample outputs of telemtry work
    Jonathan Moules
    jonathan-lists at lightpear.com
    Thu May 12 12:28:36 PDT 2022
Hi Tim,
Thanks for the login credentials. I did some fiddling with the versions:
* Some SQL to get clean QGIS versions
* QGIS Version 30-day graph now uses this (Major.Minor version only).
* 20 most used full-versions (Major.Minor.Patch) for the past week
(table) - so we can see what users are using now(ish)
* History of QGIS version use as an area graph - very cool - got it by
fiddling around with things I didn't understand. :-D
* Stacked bar graph of versions. Basically the same as history-of-qgis
but different representation (not sure as to the value of this one;
happy to delete if no-one has a use for it).
You can see them all a little over half-way down on the dashboard. -
http://feed.qgis.org/metabase/public/dashboard/df81071d-4c75-45b8-a698-97b8649d7228
Cheers,
Jonathan
On 2022-05-11 00:39, Tim Sutton wrote:
> Hi Jonathan
> Thanks for your email, see comments below:
> On Tue, May 10, 2022 at 9:05 PM Jonathan Moules
> <jonathan-lists at lightpear.com> wrote:
>     Hi Tim,
>     This looks good; I love a good dashboard. Some thoughts & bugs:
>     * Do we have telemetry for QGIS Server?
> No - I don't think we will add this.....or at least I don't have any
> current plans.
>     * The numbers on "*QGIS Open events on Windows per day - last
>     yea**r*" seem far too low. "*QGIS Daily Opens - last 30 days*" is
>     showing half a million users a day but for windows is just ~50k a
>     day, this despite windows clearly being 90+% of users per the
>     platform chart (well, one of those platform charts...).
> Only QGIS >= 3.24 reports the platform. This figure will self correct
> as more people move to more recent builds.
>     * Alternately, the pie-chart next to it: "*QGIS Daily Opens by
>     Platform - last 30 days*" is showing 86% as being "other"
>     platforms where "others" on the chart to the left of it for what
>     appears to be trying to show the same thing is only a tiny
>     percentage (< 6%?).
> Again this is explained by the lack of platform reporting in QGIS >
> 3.24 (see the little info popups on each chart).
>     * "*QGIS Daily Opens by Version - last 30 days*" - is showing some
>     of the version numbers as integers and some as floats.
> Yes I haven't figured this out yet....it could be bogus User Agents,
> custom builds of QGIS.....something else?
>     * "*QGIS Top Movers - Yesterday*" - If I sum these up I get about
>     100,000. Given the total number of users yesterday per the
>     day-chart was only about 25k higher than a Monday average, I get
>     the feeling this is averaging across all-time, meaning weekends
>     will always show a low number and weekdays will always show a high
>     number (as today). I'd suggest it should probably use the average
>     for that-day, so it's comparing like-for-like.
> Yeah this is a bit of an experiment. It compares the amount of opens
> yesterday to the average daily opens across all time. I don't know how
> informative it is, in future I may just remove it.
>     * "*QGIS Total Number of Opens in this Current Month*" at the top
>     is wrong - it's identical to "last 30 days" to its left. Also the
>     very bottom shows the number should be 3.5 million not 10 million.
> Thanks, fixed now.
>     says 499,262, but the graph (*QGIS Daily Opens - last 30 days*)
>     shows 500,359 for yesterday if I mouse over it.
> I'm not sure why they are different - will need to poke around some more.
>     Assuming it's SQL behind the scenes, I may be able to take a stab
>     at it if you want.
> Yes I would welcome your help. I will send you some credentials, but
> please tray to avoid running any queries that place a high load on the
> server.
> Regards
> Tim
>     Cheers,
>     Jonathan
>     On 2022-04-29 22:35, Tim Sutton wrote:
>>     Hi Andreas
>>     On Fri, Apr 29, 2022 at 5:00 PM Andreas Neumann
>>     <andreas at qgis.org> wrote:
>>         Hi Tim,
>>     See also my answers to Régis for more context. More comments
>>     below. Note that I share the dashboard publicly so look here
>>     especially at the little (i) indicators which I tried to populate
>>     with more defail.
>>         Looks really cool - thanks for working on this! I kind of
>>         expected the dominance of Windows as an operating system, but
>>         I am surprised to see one particular Windows (Windows 10)
>>         take such a large share. Many government agencies or
>>         companies that I know still use older Windows versions.
>>     I guess MS has been working hard to make the upgrade process
>>     smoother which is IMHO a good thing from a security point of view.
>>         I also wonder what hides behind some of the quite large bars
>>         in the category "Other"?
>>     We can break them out if needed.
>>         When it comes to QGIS versions, I think we should better
>>         aggregate only by major versions and for now ignore the minor
>>         versions. This large fragmentation into minor/minor versions
>>         seems to lead to this gigantic large bar of "Other".
>>     Yes it is on my todo list to aggregate all 3xxyy into 3xx so they
>>     show as one bucket.
>>         Question: is there any chance to put the absolute numbers in
>>         relation with the rough population size of a country. It is
>>         only natural that large countries like France, Germany, USA
>>         and Brazil open QGIS  more often than smaller countries. But
>>         put in relation with population size, the pattern could look
>>         quite different.
>>     The first map already does this. The second one shows absolute
>>     numbers per territory regardless of population.
>>         My cartography teachers told me that it is absolutely
>>         forbidden to use absolute numbers in choropleth maps -
>>         ABSOLUTELY FORBIDDEN ! Numbers always need to be put in
>>         relation with the size (area and/or population) of a country.
>>     He is probably right but I think the world of BI (Business
>>     Intelligence) has largely ignored him and the world is now
>>     littered with maps like this. I still think it is interesting to
>>     see the absolute numbers by country.
>>         Thanks a lot for your work to all people involved!
>>     No problem, and again let me extend the invitation to you to go
>>     onto the backend and help improve the dashboard, this is just my
>>     first chicken scratch. I think the real value will be to see the
>>     relative breakdown of platforms, versions countries and the
>>     changes to these over time so we can identify trends. In terms of
>>     absolute numbers I am still unsure if it tells us a real picture
>>     of how many users we have.
>>     Regards
>>     Tim
>>         Andreas
>>         On Fri, 29 Apr 2022 at 15:57, Tim Sutton <tim at kartoza.com> wrote:
>>             Hi PSC
>>             I just wanted to give you some feedback on the work we
>>             have been doing to use anonymised telemetry data from the
>>             feed to try to get a handle on the number, geography and
>>             platform choice of our user base. There are detailed
>>             notes in the image below which should explain things.
>>             Currently it has only been running about 2 weeks so the
>>             year and month charts at the end look the same, but you
>>             can expect these to diverge over time.
>>             If you have other things you would like to report on with
>>             the available data, please pop me a note. I still want to
>>             aggregate the platform  better to lump together Win, Mac,
>>             Linux and other instead of the more granular breakdown we
>>             get right now. I will do so when I get a chance.
>>             I do not plan to make the link to the live dashboard
>>             public as I don't want to put load on the feed server,
>>             but if you wish to access the dashboard, pop me a note
>>             and I will add you.
>>             https://user-images.githubusercontent.com/178003/165956926-a30c6c96-3b6b-4895-8afb-97e9ba0bd28c.png
>>             Regards
>>             Tim
>>             Tim Sutton
>>             Visit http://kartoza.com to find out about open source:
>>              * Desktop GIS programming services
>>              * Geospatial web development
>>             * GIS Training
>>             * Consulting Services
>>             Tim is a member of the QGIS Project Steering Committee
>>             _______________________________________________
>>             Qgis-psc mailing list
>>             Qgis-psc at lists.osgeo.org
>>             https://lists.osgeo.org/mailman/listinfo/qgis-psc
>>         Andreas Neumann
>>         QGIS.ORG <http://QGIS.ORG> board member (treasurer)
>>     Tim Sutton
>>     * GIS Training
> Tim Sutton
> * GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20220512/d6e781bc/attachment-0001.htm>
More information about the Qgis-psc
