[Qgis-psc] Fwd: QGIS 4.0 publicly announced - right time for propose and implement breaking changes?
Régis Haubourg
regis at qgis.org
Thu Apr 24 05:51:21 PDT 2025
Hi Vedran,
thanks for raising this proposals
On 24/04/2025 10:12, Vedran Stojnović via QGIS-PSC wrote:
> Hi PSC,
> since I didn't get any response in QGIS Developer mailing list, I am
> forwarding this to PSC mailing list, I consider this a PSC decision
> and would love to hear at least some feedback.
PSC is not driving features from above, we rely on the contributors and
help in finding consensus when it doesn't happen by itsel, or help in
funding un-fundable changes.
If your changes are small features, did you already file a feature
request in Github and discuss it there ? Good pratice is to open feature
requests, then trigger discussions in the developper's list for
implementation help or further discussion.
If you propose a massive change breaking UI, API, user workflows, you
must write down an enhancement proposal (QEP) in the dedicated
repository. Contributors will ask for implementation details, migration
plans etc.. there.
> What I'm thinking of? Few examples:
Let's discuss a closed list of items. Migrating to QGIS4.0 is not the
moment of breaking all things. This transition is a major change, but
not a rebuild from the ground up.
> 1) change some default settings for QGIS Desktop
> - e.g. left double click on layer to open attribute table for vector
> layers instead of opening properties (no other software that I used in
> my life opens properties on left double click), for raster layers it
> could do a zoom extents on raster (logic to open image on double click)
This is a legitimate feature request, rather minimal, and that could be
driven by a setting. I don't agree that opening the attribute table is
the only action that makes sense. Inkscape triggers a layer rename (F2)
for instance. opening the attribute table for massive table is probably
something you don't want to happen to easily. Not sure you will get a
consensus for the default action, but having settings for this makes
sense to me.
> 2) change name(s) of some native algorithms - I find some of them
> confusing
> - e.g. "native:polygonize" uses lines (mathematically defined lines -
> which only have start pt and end pt) and creates polygons, but we have
> also "native:linestopolygons" which by description also uses lines and
> converts them to polygons, but actually expects polylines (polygons
> drawn as line layer), and then we have gdal:polygonize which converts
> raster to vector polygons
I think that can be done directly in Pull request, as long as we have
common naming rules. I'm not sure if thess already exists, maybe we
should write minimal rules first. Could you take this action ?
> 3) remove deprecated functions from expression calculator
> 4) change logic in some algorithms/expressions
> - e.g. "point_n" function is 1-indexed instead of 0-indexed
> (QGIS/issues/29100)
Agreed. (this doesn't mean this will happen, someone has to take the
cleanup action)
> I'm sure that other developers/contributors/users have their own ideas...
> So I would love to see something like this as type of process similar
> to QEP - where a user/contributor could propose a change, and than it
> can be commented from everyone, but in the end should be voted from
> core developers or by PSC:
> - does it make sense
> - is it doable or too complicated and so on...
feature requests are the way to go. Let's address things in separate
issues / threads / pull request.
We are not obliged to push all changes in QGIS4, QGIS has a fast release
cycle exactly for this.
> We're kind of short on time, but I believe that this can be done until
> October.
Are you saying you have ressources to code things yourself?
All the best
Régis
> Srdačan pozdrav / Kind regards,
> Vedran Stojnović.
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20250424/625f9c43/attachment-0001.htm>
More information about the QGIS-PSC
