[QGIS-pt] QGIS - Estilos e Propriedades Guardadas
Alexandre Neto
senhor.neto gmail.com
Quinta-Feira, 14 de Agosto de 2014 - 05:06:46 PDT
Arrastas o ficheiro para cima do QGIS.
É certo que seria mais bonito se pudesse ser feito de dentro do QGIS,
talvez no futuro, devia abrir-se o feature request.
Alexandre Neto
On Thu, Aug 14, 2014 at 11:47 AM, Pedro <pedro.ferro gmail.com> wrote:
> Bem, até me envergonho um pouco de fazer esta pergunta mas depois de
> guardar
> o ficheiro .qlr como o carrego...?
> Ao abrir um novo projecto limpo (sem nada carregado), pretendia ir buscar
> este qlr para ele fazer o carregamento da tabela e dos estilos associados.
> (já tentei de várias formas)
> Pelo menos é o que depreendo que este formato faça, lendo o blog do Nathan:
> "/*The Layer Definition file (.qlr)*
> It contains: Layer source pointer + Style information
> This newest feature, also in plugin form for 2.0 and 2.2, is a Layer
> Definition file. This file contains the reference - or pointer - to the
> data
> source plus any style information. This is like a the ArcGIS .lyr file,
> although maybe not as fully feature rich just yet. The use case for this
> file is simple: To have a single file to can open a data source bringing in
> all the related style information. These files also allow you to mask the
> underlying datasource in a easy to open file.
> One of my use cases is to open MS SQL layers. Rather then having to go to
> the MS SQL connection dialog, connect, select and load, then style. I can
> simply add a .qlr file that points to the correct MS SQL layer pre styled.
> In the future a .qlr file may hold a reference to more then one layer. The
> Ordance Survey or Natural Earth stuff could also be done with a QLR in
> order
> too allow just opening a single file."
> http://osgeo-org.1560.x6.nabble.com/QGIS-Estilos-e-Propriedades-Guardadas-tp5148362p5156375.html
> Sent from the QGIS-pt mailing list archive at Nabble.com.
> QGIS-pt lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/qgis-pt
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/qgis-pt/attachments/20140814/6aea4c31/attachment.html>
More information about the QGIS-pt
