[QGIS-pt] ERROR: Unable to load GDAL library
Valter Albino valteralbino at gmail.com
Tue Jul 20 06:13:33 PDT 2021
Boa tarde,
Gostaria de colocar 1 questão. A tentar executar a ferramenta "grass" pelo
QGIS (versão + recente com instalação via OSGeo4W, numa máquina windows 10,
64 bits.
Creio que o que aborta o processo será a impossibilidade de utilizar a
livraria GDAL, mas não percebo como solucionar:
2021-07-20T14:05:39     INFO    GRASS GIS 7 execution console output
             Starting GRASS GIS...
             WARNING: Concurrent mapset locking is not supported on Windows
             Cleaning up temporary files...
             Executing ...
             C:\OSGeo4W\bin>chcp 1252 1>NUL
             C:\OSGeo4W\bin>g.proj -c
wkt="C:/Users/Particular/AppData/Local/Temp/processing_MbcDzX/cdd299bd36d6449fb1270f6e559b3652/crs.prj"
             Default region was updated to the new projection, but if you
have multiple mapsets `g.region -d` should be run in each to update the
region from the default
             Projection information updated
             C:\OSGeo4W\bin>r.external
input="G:\FICHEIROS_DADOS\CONSULTORIA\CM_XXX\GIS\MDT\MDT_140401v2.tif"
band=1 output="rast_60f6ca2232fda2" --overwrite -o
             Over-riding projection check
             Reading band 1 of 1...
            * ERROR: Unable to load GDAL library*
             C:\OSGeo4W\bin>g.region n=-39620.35982039999 s=-55560.3505752
e=-30548.607124000002 w=-43733.4816028 res=4.999952399999999
             C:\OSGeo4W\bin>r.fill.dir input=rast_60f6ca2232fda2
format="grass" output=output89153a1a560e43489194c61612739fcd
direction=direction89153a1a560e43489194c61612739fcd
areas=areas89153a1a560e43489194c61612739fcd --overwrite
raster=output89153a1a560e43489194c61612739fcd
             ERROR: Raster map not found
             C:\OSGeo4W\bin>r.out.gdal -t -m
input="output89153a1a560e43489194c61612739fcd"
output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\a76ab4e5d68b45f1b6c2739e58437da5\output.tif"
format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
             *ERROR: Raster map or group not found*
raster=direction89153a1a560e43489194c61612739fcd
             *ERROR: Raster map not found*
input="direction89153a1a560e43489194c61612739fcd"
output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\fde16642fbfe463c9cc71ea2c0f08ee3\direction.tif"
raster=areas89153a1a560e43489194c61612739fcd
input="areas89153a1a560e43489194c61612739fcd"
output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\cf65f88ad3124782932644f6fb6dd822\areas.tif"
             C:\OSGeo4W\bin>exit
             Execution of finished.
             Press any key to continue . . .
Ajuda, será bem vinda
Obrigado
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
URL: <http://lists.osgeo.org/pipermail/qgis-pt/attachments/20210720/b92967d4/attachment.html>
More information about the QGIS-pt mailing list
