[QGIS-pt] ERROR: Unable to load GDAL library
Giovanni Manghi giovanni.manghi at gmail.com
Tue Jul 20 06:43:08 PDT 2021
talvez seja este:
https://github.com/qgis/QGIS/issues/44155
Cumprimentos
-- G --
On Tue, Jul 20, 2021 at 2:13 PM Valter Albino <valteralbino at gmail.com> wrote:
> Boa tarde,
> Gostaria de colocar 1 questão. A tentar executar a ferramenta "grass" pelo QGIS (versão + recente com instalação via OSGeo4W, numa máquina windows 10, 64 bits.
> Creio que o que aborta o processo será a impossibilidade de utilizar a livraria GDAL, mas não percebo como solucionar:
> 2021-07-20T14:05:39     INFO    GRASS GIS 7 execution console output
>              Starting GRASS GIS...
>              WARNING: Concurrent mapset locking is not supported on Windows
>              Cleaning up temporary files...
>              Executing ...
>              C:\OSGeo4W\bin>chcp 1252 1>NUL
>              C:\OSGeo4W\bin>g.proj -c wkt="C:/Users/Particular/AppData/Local/Temp/processing_MbcDzX/cdd299bd36d6449fb1270f6e559b3652/crs.prj"
>              Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default
>              Projection information updated
>              C:\OSGeo4W\bin>r.external input="G:\FICHEIROS_DADOS\CONSULTORIA\CM_XXX\GIS\MDT\MDT_140401v2.tif" band=1 output="rast_60f6ca2232fda2" --overwrite -o
>              Over-riding projection check
>              Reading band 1 of 1...
>              C:\OSGeo4W\bin>g.region n=-39620.35982039999 s=-55560.3505752 e=-30548.607124000002 w=-43733.4816028 res=4.999952399999999
>              C:\OSGeo4W\bin>r.fill.dir input=rast_60f6ca2232fda2 format="grass" output=output89153a1a560e43489194c61612739fcd direction=direction89153a1a560e43489194c61612739fcd areas=areas89153a1a560e43489194c61612739fcd --overwrite
>              C:\OSGeo4W\bin>g.region raster=output89153a1a560e43489194c61612739fcd
>              ERROR: Raster map not found
>              C:\OSGeo4W\bin>r.out.gdal -t -m input="output89153a1a560e43489194c61612739fcd" output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\a76ab4e5d68b45f1b6c2739e58437da5\output.tif" format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
>              ERROR: Raster map or group not found
>              C:\OSGeo4W\bin>g.region raster=direction89153a1a560e43489194c61612739fcd
>              C:\OSGeo4W\bin>r.out.gdal -t -m input="direction89153a1a560e43489194c61612739fcd" output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\fde16642fbfe463c9cc71ea2c0f08ee3\direction.tif" format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
>              C:\OSGeo4W\bin>g.region raster=areas89153a1a560e43489194c61612739fcd
>              C:\OSGeo4W\bin>r.out.gdal -t -m input="areas89153a1a560e43489194c61612739fcd" output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\cf65f88ad3124782932644f6fb6dd822\areas.tif" format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
>              C:\OSGeo4W\bin>exit
>              Execution of finished.
>              Press any key to continue . . .
> Ajuda, será bem vinda
> Obrigado
> Cumprimentos,
> Valter Albino - Geógrafo Físico, M.Sc.
> Modelação H&H / Riscos ambientais / OT&U
> www.valteralbino.wixsite.com/hydrodynamics
> QGIS-pt mailing list
> QGIS-pt at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-pt
More information about the QGIS-pt mailing list
