[QGIS-pt] ERROR: Unable to load GDAL library
    Valter Albino
    valteralbino at gmail.com
    Tue Jul 20 07:12:35 PDT 2021
É possível :-)
A mesma versão 3.20.0 no portátil "laptop" executa sem problemas ...
QGIS version
3.20.0-Odense
QGIS code revision
decaadbb31 <https://github.com/qgis/QGIS/commit/decaadbb31>
Qt version
5.15.2
Python version
3.9.5
GDAL/OGR version
3.3.0
PROJ version
8.0.1
EPSG Registry database version
v10.018 (2021-04-02)
GEOS version
3.9.1-CAPI-1.14.2
SQLite version
3.35.2
PDAL version
2.3.0
PostgreSQL client version
13.0
SpatiaLite version
5.0.1
QWT version
6.1.3
QScintilla2 version
2.11.5
OS version
Windows 10 Version 1909
Obrigado
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Giovanni Manghi <giovanni.manghi at gmail.com> escreveu no dia terça,
20/07/2021 à(s) 14:44:
> talvez seja este:
> https://github.com/qgis/QGIS/issues/44155
> Cumprimentos
> -- G --
> On Tue, Jul 20, 2021 at 2:13 PM Valter Albino <valteralbino at gmail.com>
> wrote:
> > Boa tarde,
> > Gostaria de colocar 1 questão. A tentar executar a ferramenta "grass"
> pelo QGIS (versão + recente com instalação via OSGeo4W, numa máquina
> windows 10, 64 bits.
> > Creio que o que aborta o processo será a impossibilidade de utilizar a
> livraria GDAL, mas não percebo como solucionar:
> > 2021-07-20T14:05:39     INFO    GRASS GIS 7 execution console output
> >              Starting GRASS GIS...
> >              WARNING: Concurrent mapset locking is not supported on
> Windows
> >              Cleaning up temporary files...
> >              Executing ...
> >              C:\OSGeo4W\bin>chcp 1252 1>NUL
> >              C:\OSGeo4W\bin>g.proj -c
> wkt="C:/Users/Particular/AppData/Local/Temp/processing_MbcDzX/cdd299bd36d6449fb1270f6e559b3652/crs.prj"
> >              Default region was updated to the new projection, but if
> you have multiple mapsets `g.region -d` should be run in each to update the
> region from the default
> >              Projection information updated
> >              C:\OSGeo4W\bin>r.external
> input="G:\FICHEIROS_DADOS\CONSULTORIA\CM_XXX\GIS\MDT\MDT_140401v2.tif"
> band=1 output="rast_60f6ca2232fda2" --overwrite -o
> >              Over-riding projection check
> >              Reading band 1 of 1...
> >              C:\OSGeo4W\bin>g.region n=-39620.35982039999
> s=-55560.3505752 e=-30548.607124000002 w=-43733.4816028
> res=4.999952399999999
> >              C:\OSGeo4W\bin>r.fill.dir input=rast_60f6ca2232fda2
> format="grass" output=output89153a1a560e43489194c61612739fcd
> direction=direction89153a1a560e43489194c61612739fcd
> areas=areas89153a1a560e43489194c61612739fcd --overwrite
> raster=output89153a1a560e43489194c61612739fcd
> >              ERROR: Raster map not found
> >              C:\OSGeo4W\bin>r.out.gdal -t -m
> input="output89153a1a560e43489194c61612739fcd"
> output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\a76ab4e5d68b45f1b6c2739e58437da5\output.tif"
> format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
> >              ERROR: Raster map or group not found
> raster=direction89153a1a560e43489194c61612739fcd
> input="direction89153a1a560e43489194c61612739fcd"
> output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\fde16642fbfe463c9cc71ea2c0f08ee3\direction.tif"
> raster=areas89153a1a560e43489194c61612739fcd
> input="areas89153a1a560e43489194c61612739fcd"
> output="C:\Users\Particular\AppData\Local\Temp\processing_MbcDzX\cf65f88ad3124782932644f6fb6dd822\areas.tif"
> >              C:\OSGeo4W\bin>exit
> >              Execution of finished.
> >              Press any key to continue . . .
> > Ajuda, será bem vinda
> > Obrigado
> > Cumprimentos,
> > Valter Albino - Geógrafo Físico, M.Sc.
> > QGIS-pt mailing list
> > QGIS-pt at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/qgis-pt
URL: <http://lists.osgeo.org/pipermail/qgis-pt/attachments/20210720/28126374/attachment-0001.html>
More information about the QGIS-pt
