[qgis-qwc2] Transitioning from QWC1 to QWC2
Sandro Mani
manisandro at gmail.com
Mon Apr 10 05:07:10 PDT 2017
Hi
The idea with QWC2 is that you have a QGIS Server up and running which
serves the projects you want to use as WMS, and then in
themesConfig.json you specify the url to the WMS. The themesConfig.js
script (invoked via yarn run themesconfig) will then query the QGIS
Server and generate a themes.json file which contains all the infos QWC2
needs to display a theme. So the location where you need to place the
qgs files depends on your QGIS Server configuration, as far as QWC2 is
concerned, what matters is that the project is served as WMS.
Hope this helps
Sandro
On 10.04.2017 13:56, Adriano Kaulich wrote:
> Hi all,
> I was exited to learn at FOSSGIS 2017 that QWC2 was already at beta
> and wanted to try it out. I didn't realize though, that the
> architecture is very different to that of the original QWC. Once I got
> the demo app running (which was comfortably easy to do), I tried to
> investigate how the new QWC works.
> In the original QWC, *.qgs-files could be saved in the project folder,
> where the demo projects where located as well. With QWC2 though, I
> have a hard time finding the location of the demo projects, or
> understanding how I would implement my own. I have several
> QWC-Projects with the original Version that I wanted to move to the
> new QWC2. What I took away from the German documentation is, that
> projects are now called themes. But I didn't understand how to edit a
> theme with QGIS Desktop, nor was it made clear where the demo themes
> are stored as QGIS-Project files. Is there a tutorial out there that
> eases the transition from QWC1 to QWC2?
> With best regards,
> Adriano
> qgis-qwc2 mailing list
> qgis-qwc2 at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
More information about the qgis-qwc2
