[qgis-qwc2] GWC2 and GeoServer
Mauro Bartolomeoli mauro.bartolomeoli at geo-solutions.it
Mon Aug 14 02:07:43 PDT 2017
Hi Asta. If you want to have a look at MapStore2 ho to
https://mapstore2.geo-solutions.it
You will find some useful material and links to its mailing lists.
Mauro
Il 14 ago 2017 10:36 AM, "Ásta Kristín Óladóttir" <asta at alta.is> ha scritto:
Hi Karl Magnus.
Thank you very much for your informing reply.
Best regards,
Ásta
On Mon, Aug 14, 2017 at 6:18 AM, Karl Magnus Jönsson <Karl-Magnus.Jonsson@
kristianstad.se> wrote:
> Hi Asta!
> The main feature with qwc2 is to use QGIS server as a backend. QGIS is
> used to style layers, build layer tree, print layouts etc. You can connect
> to Geoserver in the QGIS project and publish the services again through
> QGIS server. qwc2 is developed in cooperation with MapStore2. Another
> option would be to use it directly since I’m sure you can use Geoserver
> services directly in another way there.
> *Karl-Magnus Jönsson* | Gis-Utvecklare
> Geografisk information
> Miljö- och samhällsbyggnadsförvaltningen
> Kristianstads kommun
> Besöksadress: Västra Storgatan 12
> Postadress: 291 80 Kristianstad
> www.kristianstad.se
> *Från:* qgis-qwc2 [mailto:qgis-qwc2-bounces at lists.osgeo.org] *För *Ásta
> Kristín Óladóttir
> *Skickat:* den 11 augusti 2017 17:38
> *Till:* qgis-qwc2 at lists.osgeo.org
> *Ämne:* [qgis-qwc2] GWC2 and GeoServer
> Hello everyone.
> I find gwc2 very promising, but is it correctly understood that in order
> to have good use of it I will have to set up QGIS Server with it, since it
> uses QGIS projects as templates and some other QGIS Server specific options
> like e.g. the PDF printer? I have been using GeoServer for some time and It
> would be very handy form me to use some naked version of gwc2 as a web map
> with various features and connect it with WMS and WFS´s layers coming from
> GeoServer.
> Best regards,
> Ásta
> __________________________
> *B.S. Landfræði *
> *Alta ehf* // +354 582 5000 <+354%20582%205000> // +354 6963239
> <+354%20696%203239>
> www.alta.is  // Alta á Twitter <http://twitter.com/alta_ehf> // Alta á
> Facebook <http://www.facebook.com/pages/Alta/161795813838691?v=wall>
> Gæða og - umhverfisstefna Alta <http://alta.is/pdf/svonavinnumvid.pdf>
*B.S. Landfræði *
*Alta ehf* // +354 582 5000 // +354 6963239 <+354%20696%203239>
qgis-qwc2 mailing list
https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20170814/bbd5c4e8/attachment-0001.html>
More information about the qgis-qwc2 mailing list
