[qgis-qwc2] compiling QWC2
Sandro Mani manisandro at gmail.com
Tue Aug 28 01:31:05 PDT 2018
Hi
This looks like a proxy issue, if you have your own qgis server running,
you can modify themesConfig.json to point to a project served by your
own qgis server, and you won't need to be able to connect to the demo
server anymore.
Best
Sandro
On 28.08.2018 09:48, Thomas Schüttenberg wrote:
> Hi!
> I am trying to compile the QWC2 acording to this documentation [1], but it seems to run only half way when executing 'yarn run prod'. Some modules are built, but e.g. the folder 'prod', in which the application bundle should land, is not created or populated.
> Instead an error in processing 'themesConfig.js' and/or 'themesConfig.json' was raised: "ERROR reading WMS GetProjectSettings of http://qwc2.sourcepole.ch/wms/themes/test" (...) "Error:
> connect ETIMEDOUT 178.22.71.6:80" (similar to #107 [2]).
> The Proxy in git, node and yarn is set properly.
> While this URL (as well as the IP in "Error: connect ECONNREFUSED 178.22.71.6:80") is reachable via Browser and I found it in themesConfig.json I think this could be just a missing customization or configuration for my part. But I have no clue what to configure (first).
> I am an absolute beginner in compiling, so hopefully someone can show me the way into this mystery.
> [1] https://github.com/qgis/qwc2-demo-app/blob/master/doc/QWC2_Documentation.md
> [2] https://github.com/qgis/qwc2-demo-app/issues/107
> clueless
> Thomas
> qgis-qwc2 mailing list
> qgis-qwc2 at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
More information about the qgis-qwc2 mailing list
