[qgis-qwc2] qwc2 questions
info
info at vtadrones.com
Sun Sep 16 07:58:25 PDT 2018
A mod @ GIS stack exchange put my question on hold. So here is the
question:
*QUESTION: *
Ubuntu 18
* I have problems with QGIS web client 2 features after install &
configure w/ QGIS server.
* I must be doing something incorrect with the project html link if I am
seeing these issues i detail below, because in the demo all works
correctly and the html links do not include wms request.
* I see the html links in the demo themesConfig.json are like this:
http://qwc2.sourcepole.ch/wms/themes/test
*so no capabilities request or WMS? When i leave out the wms request
from the html yarn does not want to reload the theme even after symbolic
links for project source, wms xml, & mapserv.fcgi
* I can only get the map to appear when I do the html link like this:
http://qgis.demo/cgi-bin/projects/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
I assume this is the core of the issues I am seeing. What am I missing?
*ISSUES:*
1: when I use print function, I get 500 internal server error after
pressing "print" button.
- test project has a print composer profile setup.
- something in themesConfig.json or Config.json missing or incorrect
possibly
2: when I click on the map the pop up window that would show map feature
details in the demo quickly disappears and I am sent to a blank white
screen and I must refresh browser to get the map back.
- this feature was working with demo project sources & broke when I
added my source
3: When I export RASTER & DXF I get "unable to connect localhost:5000"
- same in demo & after I added my project source.
- I see in config.json i need to configure proxy, but details are limited.
4: when I access QWC2 from another system on the network, I am unable to
see the test project. The thumbnail and project layers are not showing up.
*DOCS USED:*
* Followed steps here for QGIS server install, sections 12.1 & 12.2:
https://docs.qgis.org/2.18/en/docs/training_manual/qgis_server/index.html
* Followed steps here for QGIS web client 2 after 12.2.6 QGIS-server
instructions said to use the older QWC version:
https://github.com/qgis/qwc2-demo-app/blob/master/doc/QWC2_Documentation.md
**RESULTS:*
* QGIS install was successful
- can send WMS get capabilities and map requests.
https://i.stack.imgur.com/o7WVR.png
* QWC2 demo install was successful
- all features working with demo project sources (expect export RASTER &
DXF, I get "unable to connect localhost:5000")
https://i.stack.imgur.com/k9E1p.png
* I modified the themesConfig.json & the test project (world.qgs)
displays in QWC2 locally on server:
http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=/home/qgis/projects/world.qgs
or
This (w/ symbolic links):
https://i.stack.imgur.com/K7qxo.png
https://i.stack.imgur.com/juOpa.png
On 9/16/2018 12:20 AM, info wrote:
> Hello :)
> This is a great app! I am very excited I found this. Very clean and
> useful. Thank you for your development on this project.
> I have some configuration issues with QWC2 & QGIS server. I made a
> detailed post on GIS stack exchange. I was hoping you might be able to
> assist. I appreciate any help you can provide.
> https://gis.stackexchange.com/questions/296056/qgis-web-client-2-qgis-server-configuration-questions-issues
> Regards,
> Justin Van Fleet
> qgis-qwc2 mailing list
> qgis-qwc2 at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20180916/b7a3eb13/attachment.html>
More information about the qgis-qwc2
