[qgis-qwc2] map tips
Sandro Mani manisandro at gmail.com
Thu Feb 14 05:03:58 PST 2019
Hi Bernhard
Yes, that would be a server issue (resp your server does not support
that option, not sure exactly when it was added, probably some 3.x
release as stated by Andreas earlier).
Sandro
On 14.02.19 14:01, Bernhard Ströbl wrote:
> Hi Sandro,
> although the GetFeature-Request is sent with "with_maptip=false" the
> maptip field is returned, so it seems to be a server problem, isn't it?
> Bernhard
> Am 14.02.2019 um 11:47 schrieb Sandro Mani:
>> Hi Bernhard
>> Have you changed both the mobile and desktop configurations in
>> config.json (resp. the one that you are testing?)
>> Sandro
>> On 14.02.19 11:46, Bernhard Ströbl wrote:
>>> Am 14.02.2019 um 11:27 schrieb Sandro Mani:
>>>> Hi Bernhard
>>>> If you look in the network inspector, do you see you change
>>>> reflected in the GetFeatureInfo request URL?
>>> no, the GetFeatureInfo request is sent with "with_maptip=true"
>>>> feature_count simply limits the number of features QGIS Server
>>>> returns.
>>> I would have guessed :-)
>>> Bernhard
>>>> Sandro
>>>> On 14.02.19 11:26, Bernhard Ströbl wrote:
>>>>> Hi Sandro,
>>>>> doesn't work here. Is a certain Version of QGIS Server and/or qwc2
>>>>> required?
>>>>> BTW what is "feature_count" good for?
>>>>> Bernhard
>>>>> Am 14.02.2019 um 11:15 schrieb Sandro Mani:
>>>>>> Hi
>>>>>> This is already possible, just set:
>>>>>> with_maptip: false
>>>>>> in the Identify cf params in config.json, i.e.
>>>>>>            "name": "Identify",
>>>>>>            "cfg": {
>>>>>>              "params": {
>>>>>>                "FI_POINT_TOLERANCE": 32,
>>>>>>                "FI_LINE_TOLERANCE": 16,
>>>>>>                "FI_POLYGON_TOLERANCE": 8,
>>>>>>                "feature_count": 20,
>>>>>>                "with_maptip": false
>>>>>> Best
>>>>>> Sandro
>>>>>> On 14.02.19 08:17, Andreas Neumann wrote:
>>>>>>> Hi,
>>>>>>> Now that we can do GetFeatureInfo WITH_MAPTIP true|false, QWC2
>>>>>>> could use with maptip for mouseover and without maptip for click.
>>>>>>> This should be relatively easy to implement - right?
>>>>>>> Greetings,
>>>>>>> Andreas
>>>>>>> On 2019-02-14 08:06, Bernhard Ströbl wrote:
>>>>>>>> Hi Sandro,
>>>>>>>> it works with maptip (used to be tooltip in QWC1).
>>>>>>>> Unfortunately when clicking on a feature the field maptip is
>>>>>>>> included in the feature info, too, which IMHO is kinda ungly.
>>>>>>>> Bernhard
>>>>>>>> Am 07.02.2019 um 23:44 schrieb Sandro Mani:
>>>>>>>>> Hi Bernhard
>>>>>>>>> Does your GetFeatureInfo reply include a feature with an
>>>>>>>>> attribute named "maptip"?
>>>>>>>>> Best
>>>>>>>>> Sandro
>>>>>>>>> On 07.02.19 17:38, Bernhard Ströbl wrote:
>>>>>>>>>> Hi all,
>>>>>>>>>> I am trying to understand the map tips in QWC2. When enabling
>>>>>>>>>> them I see GetFeatureInfo requests being sent while moving
>>>>>>>>>> the mouse cursor. These very GetFeatureInfo requests being
>>>>>>>>>> entered in a new browser tab return an answer with feature
>>>>>>>>>> info but in qwc2-demo-app nothing happens. I would expect a
>>>>>>>>>> popup or similar.
>>>>>>>>>> Is there anything I have overlooked to configure in my QGIS
>>>>>>>>>> Server project or in my qwc2 client?
>>>>>>>>>> any help appreciated
>>>>>>>>>> Bernhard
>>>>>>>>>> __________ Information from ESET Mail Security, version of
>>>>>>>>>> virus signature database 18837 (20190207) __________
>>>>>>>>>> The message was checked by ESET Mail Security.
>>>>>>>>>> http://www.eset.com
> __________ Information from ESET Mail Security, version of virus
> signature database 18873 (20190214) __________
> http://www.eset.com
More information about the qgis-qwc2 mailing list
