[qgis-qwc2] map tips
Bernhard Ströbl bernhard.stroebl at jena.de
Thu Feb 14 06:01:19 PST 2019
Hi Sandro,
after updating the server to 3.4.4 (used to be 3.4.1) the maptip field
is gone. Thank you for your help.
Bernhard
Am 14.02.2019 um 14:03 schrieb Sandro Mani:
> Hi Bernhard
> Yes, that would be a server issue (resp your server does not support
> that option, not sure exactly when it was added, probably some 3.x
> release as stated by Andreas earlier).
> Sandro
> On 14.02.19 14:01, Bernhard Ströbl wrote:
>> Hi Sandro,
>> although the GetFeature-Request is sent with "with_maptip=false" the
>> maptip field is returned, so it seems to be a server problem, isn't it?
>> Bernhard
>> Am 14.02.2019 um 11:47 schrieb Sandro Mani:
>>> Hi Bernhard
>>> Have you changed both the mobile and desktop configurations in
>>> config.json (resp. the one that you are testing?)
>>> Sandro
>>> On 14.02.19 11:46, Bernhard Ströbl wrote:
>>>> Am 14.02.2019 um 11:27 schrieb Sandro Mani:
>>>>> Hi Bernhard
>>>>> If you look in the network inspector, do you see you change
>>>>> reflected in the GetFeatureInfo request URL?
>>>> no, the GetFeatureInfo request is sent with "with_maptip=true"
>>>>> feature_count simply limits the number of features QGIS Server
>>>>> returns.
>>>> I would have guessed :-)
>>>> Bernhard
>>>>> Sandro
>>>>> On 14.02.19 11:26, Bernhard Ströbl wrote:
>>>>>> Hi Sandro,
>>>>>> doesn't work here. Is a certain Version of QGIS Server and/or qwc2
>>>>>> required?
>>>>>> BTW what is "feature_count" good for?
>>>>>> Bernhard
>>>>>> Am 14.02.2019 um 11:15 schrieb Sandro Mani:
>>>>>>> Hi
>>>>>>> This is already possible, just set:
>>>>>>> with_maptip: false
>>>>>>> in the Identify cf params in config.json, i.e.
>>>>>>>            "name": "Identify",
>>>>>>>            "cfg": {
>>>>>>>              "params": {
>>>>>>>                "FI_POINT_TOLERANCE": 32,
>>>>>>>                "FI_LINE_TOLERANCE": 16,
>>>>>>>                "FI_POLYGON_TOLERANCE": 8,
>>>>>>>                "feature_count": 20,
>>>>>>>                "with_maptip": false
>>>>>>> Best
>>>>>>> Sandro
>>>>>>> On 14.02.19 08:17, Andreas Neumann wrote:
>>>>>>>> Hi,
>>>>>>>> Now that we can do GetFeatureInfo WITH_MAPTIP true|false, QWC2
>>>>>>>> could use with maptip for mouseover and without maptip for click.
>>>>>>>> This should be relatively easy to implement - right?
>>>>>>>> Greetings,
>>>>>>>> Andreas
>>>>>>>> On 2019-02-14 08:06, Bernhard Ströbl wrote:
>>>>>>>>> Hi Sandro,
>>>>>>>>> it works with maptip (used to be tooltip in QWC1).
>>>>>>>>> Unfortunately when clicking on a feature the field maptip is
>>>>>>>>> included in the feature info, too, which IMHO is kinda ungly.
>>>>>>>>> Bernhard
>>>>>>>>> Am 07.02.2019 um 23:44 schrieb Sandro Mani:
>>>>>>>>>> Hi Bernhard
>>>>>>>>>> Does your GetFeatureInfo reply include a feature with an
>>>>>>>>>> attribute named "maptip"?
>>>>>>>>>> Best
>>>>>>>>>> Sandro
>>>>>>>>>> On 07.02.19 17:38, Bernhard Ströbl wrote:
>>>>>>>>>>> Hi all,
>>>>>>>>>>> I am trying to understand the map tips in QWC2. When enabling
>>>>>>>>>>> them I see GetFeatureInfo requests being sent while moving
>>>>>>>>>>> the mouse cursor. These very GetFeatureInfo requests being
>>>>>>>>>>> entered in a new browser tab return an answer with feature
>>>>>>>>>>> info but in qwc2-demo-app nothing happens. I would expect a
>>>>>>>>>>> popup or similar.
>>>>>>>>>>> Is there anything I have overlooked to configure in my QGIS
>>>>>>>>>>> Server project or in my qwc2 client?
>>>>>>>>>>> any help appreciated
>>>>>>>>>>> Bernhard
>>>>>>>>>>> __________ Information from ESET Mail Security, version of
>>>>>>>>>>> virus signature database 18837 (20190207) __________
>>>>>>>>>>> The message was checked by ESET Mail Security.
>>>>>>>>>>> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 18874 (20190214) __________
http://www.eset.com
More information about the qgis-qwc2 mailing list
