[qgis-qwc2] How to display local KML files inside the map
Sandro Mani manisandro at gmail.com
Mon Jan 13 02:50:42 PST 2020
Hi Roman
Make sure the sample data you are trying to display is actually located
somewhere in the extent of your theme, otherwise it might be that you
don't see it just because it's somewhere far away.
Supported formats are KML and GeoJSON. For instance, you can also export
a redlining layer to GeoJSON from the layertree and then re-import that
file.
Sandro
On 10.01.20 13:06, Roman Meier wrote:
> Hi folks,
> The demo-app allows the display of data stored locally in a file.
> Unfortunately I couldn't find any documentation on this topic related to
> QWC2.
> It appears though that KML files are supported. I downloaded a sample file
> from https://developers.google.com/kml/documentation/kml_tut.
> This file seams to be read and the file size is displayed but upon click
> on "Add layer" nothing happens.
> Es there a sample file known to work in the demo-app so I can test this?
> Kind regards,
> Roman
> qgis-qwc2 mailing list
> qgis-qwc2 at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
More information about the qgis-qwc2 mailing list
