[qgis-qwc2] How to display local KML files inside the map
Roman Meier roman.meier at gismap.ch
Tue Jan 21 04:52:16 PST 2020
Hi Sandro,
I'm using the last theme of the demo-app which covers the whole world. The
kml file contains data located in USA. It shows nicely using QGIS.
The issue seems to be that the layer is not added upon clicking "Add
layer". Shouldn't the layer be added to the layer tree?
This is not happening here.
Kind regards,
Roman
> Hi Roman
> Make sure the sample data you are trying to display is actually located
> somewhere in the extent of your theme, otherwise it might be that you
> don't see it just because it's somewhere far away.
> Supported formats are KML and GeoJSON. For instance, you can also export
> a redlining layer to GeoJSON from the layertree and then re-import that
> file.
> Sandro
> On 10.01.20 13:06, Roman Meier wrote:
>> Hi folks,
>> The demo-app allows the display of data stored locally in a file.
>> Unfortunately I couldn't find any documentation on this topic related to
>> QWC2.
>> It appears though that KML files are supported. I downloaded a sample
>> file
>> from https://developers.google.com/kml/documentation/kml_tut.
>> This file seams to be read and the file size is displayed but upon click
>> on "Add layer" nothing happens.
>> Es there a sample file known to work in the demo-app so I can test this?
>> Kind regards,
>> Roman
>> qgis-qwc2 mailing list
>> qgis-qwc2 at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
More information about the qgis-qwc2 mailing list
