[qgis-qwc2] How to display local KML files inside the map
Roman Meier roman.meier at gismap.ch
Thu Jan 23 23:59:46 PST 2020
Hi Sandro,
Thanks for the tip regarding import/export of redlining layers.
Works beautifully!
Kind regards,
Roman
> Hi Roman
> Make sure the sample data you are trying to display is actually located
> somewhere in the extent of your theme, otherwise it might be that you
> don't see it just because it's somewhere far away.
> Supported formats are KML and GeoJSON. For instance, you can also export
> a redlining layer to GeoJSON from the layertree and then re-import that
> file.
> Sandro
> On 10.01.20 13:06, Roman Meier wrote:
>> Hi folks,
>> The demo-app allows the display of data stored locally in a file.
>> Unfortunately I couldn't find any documentation on this topic related to
>> QWC2.
>> It appears though that KML files are supported. I downloaded a sample
>> file
>> from https://developers.google.com/kml/documentation/kml_tut.
>> This file seams to be read and the file size is displayed but upon click
>> on "Add layer" nothing happens.
>> Es there a sample file known to work in the demo-app so I can test this?
>> Kind regards,
>> Roman
>> qgis-qwc2 mailing list
>> qgis-qwc2 at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
More information about the qgis-qwc2 mailing list
