[qgis-qwc2] Qgis-qwc2 problems with maps not being centered
    Joel Tejeda
    joel at karmacomputing.co.uk
    Mon Jun  6 15:09:43 PDT 2022
Hi Qgis-qwc2 contributors,
We have managed to install the docker qwc2 to a test server, but we have a problem when the some maps load. There are several maps are not being centered correctly which make it hard to find one the qgis load.
Here we have two examples:
1. Working qgis map:
https://maps.jtkarma.co.uk/?t=BroadwayGC/BroadwayGC/Broadway <https://maps.jtkarma.co.uk/?t=BroadwayGC/BroadwayGC/Broadway>
2. Non centered qgis map:
https://maps.jtkarma.co.uk/?t=OrsettGC/OrsettGC/OrsettGC <https://maps.jtkarma.co.uk/?t=OrsettGC/OrsettGC/OrsettGC>
The configuration:
https://maps.jtkarma.co.uk/config.json <https://maps.jtkarma.co.uk/config.json>
Things we have tried:
. Opening in QGIS Desktop to find any problems with labels.
. Changing config.json settings such as:
	urlPositionFormat: changed to centerAndZoom or extent
	preserveExtentOnThemeSwitch:  true or false
. Checking the difference between both qgis files.
It is important to note: The exact same map project files open just fine (centered correctly) in qgis desktop version 3.22.2-Białowieża, on operating system Ubuntu and Mac, and I have also seen it working on an older version of qgis with the format .ecw which now is not supported so converted to .tiff
I've uploaded 2 zips one with the qgis file, layers and tiff image from the one thats working and the other one that is not centered.
Can you please help us or guide us on how to fix this error?
The qgis map files of the centered and working map
https://drive.google.com/file/d/1_WL4MR2YruoCJOY_RxX9WibYn1tm1dhB/view?usp=sharing <https://drive.google.com/file/d/1_WL4MR2YruoCJOY_RxX9WibYn1tm1dhB/view?usp=sharing>
THe qgis map files of the non centered maps
https://drive.google.com/file/d/1FVwGmA0i8qVMZcyYyzzsW83e8pVxMe7i/view?usp=sharing <https://drive.google.com/file/d/1FVwGmA0i8qVMZcyYyzzsW83e8pVxMe7i/view?usp=sharing>
kind regards,
Joel
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20220606/e7a08fc9/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20220606/e7a08fc9/attachment-0002.png>
Name: Screen Shot 2022-06-06 at 5.14.40 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20220606/e7a08fc9/attachment-0003.png>
More information about the qgis-qwc2
