[qgis-qwc2] Qgis-qwc2 problems with maps not being centered
Benoît Blanc
benoit.blanc at oslandia.com
Fri Jun 10 09:08:45 PDT 2022
Hi Joel,
I did not test your QGIS projects but you can set the default extent of
your project centered on your data in QGIS Server tab of your project
properties. Then click on the check box "Advertised extent" and set your
extent (or click on the button to use the current canvas extent).
Also, you can customize your projects by filling the form and check
"Service Capabilities". Then, you have to upload your QGIS project in
your QGIS Server container at the right location.
Hope it will help you !
Benoît Blanc
Développeur SIG
Oslandia
Le 07/06/2022 à 00:09, Joel Tejeda a écrit :
> Hi Qgis-qwc2 contributors,
> We have managed to install the docker qwc2 to a test server, but we
> have a problem when the some maps load. There are several maps are not
> being centered correctly which make it hard to find one the qgis load.
> Here we have two examples:
> 1. Working qgis map:
> https://maps.jtkarma.co.uk/?t=BroadwayGC/BroadwayGC/Broadway
> 2. Non centered qgis map:
> https://maps.jtkarma.co.uk/?t=OrsettGC/OrsettGC/OrsettGC
> The configuration:
> https://maps.jtkarma.co.uk/config.json
> Things we have tried:
> . Opening in QGIS Desktop to find any problems with labels.
> . Changing config.json settings such as:
> urlPositionFormat: changed to centerAndZoom or extent
> preserveExtentOnThemeSwitch: true or false
> . Checking the difference between both qgis files.
> It is important to note: The exact same map project files open just
> fine (centered correctly) in qgis desktop version 3.22.2-Białowieża,
> on operating system Ubuntu and Mac, and I have also seen it working on
> an older version of qgis with the format .ecw which now is not
> supported so converted to .tiff
> I've uploaded 2 zips one with the qgis file, layers and tiff image
> from the one thats working and the other one that is not centered.
> Can you please help us or guide us on how to fix this error?
> The qgis map files of the centered and working map
> https://drive.google.com/file/d/1_WL4MR2YruoCJOY_RxX9WibYn1tm1dhB/view?usp=sharing
> THe qgis map files of the non centered maps
> https://drive.google.com/file/d/1FVwGmA0i8qVMZcyYyzzsW83e8pVxMe7i/view?usp=sharing
> kind regards,
> Joel
> qgis-qwc2 mailing list
> qgis-qwc2 at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20220610/cb5484d3/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20220610/cb5484d3/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20220610/cb5484d3/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20220610/cb5484d3/attachment-0005.png>
More information about the qgis-qwc2
