[qgis-qwc2] 3D Maps in QWC2
Sandro Mani
manisandro at gmail.com
Wed Apr 2 03:12:36 PDT 2025
Hello
I've published some initial documentation in the Plugin docs here [1].
You'll want to use master rather than 2025-lts as development has
already progressed a lot since the 2025-lts release. For a concrete
example, check out [2] and for an configuration example the map3d
configuration block in [3].
Hope this helps.
Kind regards
Sandro
[1] https://qwc-services.github.io/master/references/qwc2_plugins/#view3d
[2] https://qwc2.sourcepole.ch/?t=zh_1&c=2684298%2C1246171&s=20000
[3] https://qwc2.sourcepole.ch/themes.json
On 02.04.25 10:31, Frantisek Kobzik via qgis-qwc2 wrote:
> Hello everybody,
> I watched the FOSSGIS 2025 sessions about the cool new 3D functions of
> QWC2, but unfortunately I cannot find any hints about setting this up
> in my environment. For testing, I used the 2025-lts version of
> qwc-services, which should already have the 3D functionality.
> Could anyone point me to some instructions/config examples?
> Thank you very much.
> Cheers,
> Franky
> qgis-qwc2 mailing list
> qgis-qwc2 at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
More information about the qgis-qwc2
