[qgis-qwc2] 3D Maps in QWC2
Frantisek Kobzik
frantisek.kobzik at th-deg.de
Wed Apr 2 03:20:00 PDT 2025
Hello Sandro,
awesome, that's exactly I was looking for. Thank you!
Cheers,
Franky
Am 02.04.25 um 12:12 schrieb Sandro Mani:
> Hello
> I've published some initial documentation in the Plugin docs here [1].
> You'll want to use master rather than 2025-lts as development has
> already progressed a lot since the 2025-lts release. For a concrete
> example, check out [2] and for an configuration example the map3d
> configuration block in [3].
> Hope this helps.
> Kind regards
> Sandro
> [1] https://qwc-services.github.io/master/references/qwc2_plugins/#view3d
> [2] https://qwc2.sourcepole.ch/?t=zh_1&c=2684298%2C1246171&s=20000
> [3] https://qwc2.sourcepole.ch/themes.json
> On 02.04.25 10:31, Frantisek Kobzik via qgis-qwc2 wrote:
>> Hello everybody,
>> I watched the FOSSGIS 2025 sessions about the cool new 3D functions
>> of QWC2, but unfortunately I cannot find any hints about setting this
>> up in my environment. For testing, I used the 2025-lts version of
>> qwc-services, which should already have the 3D functionality.
>> Could anyone point me to some instructions/config examples?
>> Thank you very much.
>> Cheers,
>> Franky
>> qgis-qwc2 mailing list
>> qgis-qwc2 at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
More information about the qgis-qwc2
