[qgis-qwc2] Setting up LDAP authentication with QWC2
Cahill, Benjamin
bcahill at alertacademy.com
Thu Apr 24 08:35:18 PDT 2025
Hello,
I am new to the QGIS world but loving it. I have set up QWC2 using
Docker and it is working well. I would like to set up LDAP
authentication, but I'm not sure where to start.
The only documentation I found was on this page:
https://qwc-services.github.io/master/references/qwc-ldap-auth_readme/
I added the qwc-ldap-auth container to my docker-compose
configuration, but I don't know what to do next.
Do I need to add users to the qwc_admin area first before authenticating?
Do I need to remove the qwc-db-auth container?
Does the qwc-ldap-auth container need access to the qwc-services configuration?
Do I need to change anything to the config-in directory?
Is my docker-compose configuration for this correct, or do I need to
change anything? (sensitive details have been obfuscated)
qwc-ldap-auth:
container_name: qwc-ldap-auth
image: sourcepole/qwc-ldap-auth:v2024.2-lts
restart: unless-stopped
environment:
LDAP_HOST: domaincontroller.mydomain.com
LDAP_PORT: 3269
LDAP_USE_SSL: True
LDAP_BASE_DN: DC=mydomain, DC=com
LDAP_USER_DN:
LDAP_BIND_USER_DN: CN=lookupUser, CN=Users, DC=mydomain, DC=com
LDAP_BIND_USER_PASSWORD: password
LDAP_USER_LOGIN_ATTR: sAMAccountName
Thank you very much for your time.
- Benjamin
More information about the qgis-qwc2
