[qgis-qwc2] Setting up LDAP authentication with QWC2
Daniel Cebulla
daniel.cebulla at jena.de
Fri Apr 25 00:28:39 PDT 2025
Hi Benjamin,
You have to configure the service endpoint also:
https://qwc-services.github.io/master/configuration/ServiceConfiguration/#enabling-additional-services
So for instance set
SERVICE_MOUNTPOINT: '/ldap'
as environment variable in the container.
Then you have to set this endpoint in your tenantConfig.json on several
positions.
You have to set this as "auth_service_url" within the mapViewer Config:
https://github.com/qwc-services/qwc-docker/blob/master/volumes/config-in/default/tenantConfig.json#L101
"auth_service_url": "/ldap/",
Authentication works for ogc-service, feature-info-service,
legend-service and document-service. In their configs you have to set
the service-URL there:
https://qwc-services.github.io/master/references/qwc-ogc-service/#config_basic_auth_login_url
https://qwc-services.github.io/master/references/qwc-feature-info-service/#config_basic_auth_login_url
https://qwc-services.github.io/master/references/qwc-legend-service/#config_basic_auth_login_url
https://qwc-services.github.io/master/references/qwc-document-service/#config_basic_auth_login_url
Here you can specify the ldap service only (the exact url is related to
your nginx config):
"basic_auth_login_url": "http://qwc-ldap-service:9090/verify_login"
Another posibility is to set an array of more than one service:
"basic_auth_login_url": [
"http://qwc-auth-service:9090/verify_login",
In this case, the authentication is tried with the db-auth-service first
and if there is no match the ldap-service is used. The parameter name
"basic_auth_login_url" is a little bit missleading here. As the ldap and
oidc services are developed after the db-auth service the parameter name
was kept for backward compatibility.
The Container does not need any volume mounts to the configs.
I think, you don't need the qwc-db-auth service anymore, if you just
want to authenticate via the ldap-service.
A hint: You can set up the permissions on group level only (and not on
user level) within the admin-gui. Then you have to configure this groups
as ldap-groups on your ldap-users aswell and the authentication should
check the ldap groups against the configured groups within the config-db.
Hope that helps!
Greetings, Daniel
Daniel Cebulla
Application support GIS
on behalf of Dr. Arndt Döhler
Phone: +493641 49-5190 Mail: daniel.cebulla at jena.de
Kommunale Informationstechnik und Telekommunikation (KITT)
Municipal enterprise Director of Operations: Dr. Arndt Döhler
of the city of Jena Paradiesstr. 6, 07743 Jena
Am 24.04.25 um 17:35 schrieb Cahill, Benjamin via qgis-qwc2:
> Hello,
> I am new to the QGIS world but loving it. I have set up QWC2 using
> Docker and it is working well. I would like to set up LDAP
> authentication, but I'm not sure where to start.
> The only documentation I found was on this page:
> https://qwc-services.github.io/master/references/qwc-ldap-auth_readme/
> I added the qwc-ldap-auth container to my docker-compose
> configuration, but I don't know what to do next.
> Do I need to add users to the qwc_admin area first before authenticating?
> Do I need to remove the qwc-db-auth container?
> Does the qwc-ldap-auth container need access to the qwc-services configuration?
> Do I need to change anything to the config-in directory?
> Is my docker-compose configuration for this correct, or do I need to
> change anything? (sensitive details have been obfuscated)
> qwc-ldap-auth:
> container_name: qwc-ldap-auth
> image: sourcepole/qwc-ldap-auth:v2024.2-lts
> restart: unless-stopped
> environment:
> LDAP_HOST: domaincontroller.mydomain.com
> LDAP_PORT: 3269
> LDAP_USE_SSL: True
> LDAP_BASE_DN: DC=mydomain, DC=com
> LDAP_USER_DN:
> LDAP_BIND_USER_DN: CN=lookupUser, CN=Users, DC=mydomain, DC=com
> LDAP_BIND_USER_PASSWORD: password
> LDAP_USER_LOGIN_ATTR: sAMAccountName
> Thank you very much for your time.
> - Benjamin
> qgis-qwc2 mailing list
> qgis-qwc2 at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
More information about the qgis-qwc2
