[qgis-qwc2] Redirect to login page for unauthenticated users
Benjamin Cahill
bcahill at alertacademy.com
Thu May 1 08:48:39 PDT 2025
Hello,
Is there a way to redirect users that are not logged in to the login page?
I found the "auth_required" option documented on the following page:
https://qwc-services.github.io/master/references/qwc-map-viewer/
But even after adding it to tenantConfig.json and re-generating the
config, it still does not redirect a new unauthenticated user (fresh
incognito window) to the login page.
"name": "mapViewer",
"generator_config": {
"qwc2_config": {
"qwc2_config_file": "/srv/qwc_service/config-in/default/config.json",
"qwc2_index_file": "/srv/qwc_service/config-in/default/index.html"
"config": {
"qwc2_path": "/qwc2/",
"auth_service_url": "/ldap/",
"data_service_url": "/api/v1/data/",
"#document_service_url": "/api/v1/document/",
"elevation_service_url": "/elevation/",
"info_service_url": "/api/v1/featureinfo/",
"legend_service_url": "/api/v1/legend/",
"mapinfo_service_url": "/api/v1/mapinfo/",
"ogc_service_url": "/ows/",
"permalink_service_url": "/api/v1/permalink/",
"#print_service_url": "/api/v1/print/",
"search_service_url": "/api/v2/search/",
"search_data_service_url": "/api/v2/search/geom/",
"auth_required": true
I did try forcing a redirect from my webserver config by checking for
an access_token_cookie cookie, but that introduced other problems.
Does anyone know how to get the auth_required option to redirect
unauthenticated users to the login page?
Thank you,
- Benjamin
More information about the qgis-qwc2
