[qgis-qwc2] Redirect to login page for unauthenticated users
Sandro Mani manisandro at gmail.com
Sat May 3 07:13:18 PDT 2025
Hello
Do you see auth_required: true in the generated mapViewerConfig.json?
Sandro
On 01.05.25 17:48, Benjamin Cahill via qgis-qwc2 wrote:
> Hello,
> Is there a way to redirect users that are not logged in to the login page?
> I found the "auth_required" option documented on the following page:
> https://qwc-services.github.io/master/references/qwc-map-viewer/
> But even after adding it to tenantConfig.json and re-generating the
> config, it still does not redirect a new unauthenticated user (fresh
> incognito window) to the login page.
>        "name": "mapViewer",
>        "generator_config": {
>          "qwc2_config": {
>            "qwc2_config_file": "/srv/qwc_service/config-in/default/config.json",
>            "qwc2_index_file": "/srv/qwc_service/config-in/default/index.html"
>        "config": {
>          "qwc2_path": "/qwc2/",
>          "auth_service_url": "/ldap/",
>          "data_service_url": "/api/v1/data/",
>          "#document_service_url": "/api/v1/document/",
>          "elevation_service_url": "/elevation/",
>          "info_service_url": "/api/v1/featureinfo/",
>          "legend_service_url": "/api/v1/legend/",
>          "mapinfo_service_url": "/api/v1/mapinfo/",
>          "ogc_service_url": "/ows/",
>          "permalink_service_url": "/api/v1/permalink/",
>          "#print_service_url": "/api/v1/print/",
>          "search_service_url": "/api/v2/search/",
>          "search_data_service_url": "/api/v2/search/geom/",
>          "auth_required": true
> I did try forcing a redirect from my webserver config by checking for
> an access_token_cookie cookie, but that introduced other problems.
> Does anyone know how to get the auth_required option to redirect
> unauthenticated users to the login page?
> Thank you,
>   - Benjamin
> qgis-qwc2 mailing list
> qgis-qwc2 at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
More information about the qgis-qwc2 mailing list
