[Qgis-tr] [Qgis-community-team] latex/pdf guru's for failing Korean and Hindi pdf build available?
BJ Jang
qgis.tr.kr at gmail.com
Sat Jul 19 01:18:46 PDT 2014
Dera Ko.
Thanks for your hard work.
Your work is so helpful to me and many Korean.
When I went to FOSS4G Osaka last year, I saw you or not, I do not know.
If I go to Japan again, I will meet you and I would like to show
appreciation.
See you~
Regards
BJ Jang.
2014-07-19 17:10 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
> Hi Richard,
> Sorry for my late update.
> I just sent pull request to Github upstream repository,
> so could you check it and if there is no problem, merge it to master?
> [Xelatex support for Korean and Hindi #239]
> https://github.com/qgis/QGIS-Documentation/pull/239
> And sorry, I still don't know well about current documentation server.
> (Is it already Docker + Debian/Wheezy?)
> If it is Debian/Squeeze, then please let me know.
> I will try to check additional required packages and find
> how to upgrade xeCJK version manually. (But it may take some time...)
> If it is already Debian/Wheezy, then please install the following
> additional packages.
> https://github.com/sanak/QGIS-Documentation/blob/vagrant/vagrant/wheezy64/bootstrap.sh#L23-L27
> Regards,
> Ko
> 2014-06-21 16:55 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
> > Hi BJ Jang,
> > Okay!
> > Thanks for your confirmation.
> > Regards,
> > Ko
> > 2014-06-21 16:09 GMT+09:00 BJ Jang <qgis.tr.kr at gmail.com>:
> >> Dear Ko
> >> Thank you so much!!!
> >> We got a perfect Korean pdf translation.
> >> All about formatting(Font, spacing, images) is good!
> >> Thank you again Ko.
> >> Regards
> >> BJ Jang
> >> 2014-06-20 21:23 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
> >>> Hi BJ Jang, Hindi translator, Richard
> >>> > BJ Jang
> >>> I fixed Korean space issue by using Debian Wheezy newer xeCJK module,
> >>> and applying the following link way.
> >>> 2014-06-17 21:32 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
> >>> > [1]
> http://tex.stackexchange.com/questions/17292/how-to-write-spaces-between-korean-words-with-xecjk/
> >>> So, could you check the following new PDF again?
> >>> Korean PDF:
> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-ko-wheezy.pdf
> >>> > Hindi translator
> >>> I added Hindi version PDF here.
> >>> Hindi PDF:
> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-hi-wheezy.pdf
> >>> I hope that someone check this one.
> >>> > Richard
> >>> I updated my "xelatex" branch to fix Korean space issue and add Hindi
> >>> extra settings.
> >>> If above files are valid ones, I will create pull request.
> >>> == [xelatex] ==
> >>> branch root: https://github.com/sanak/QGIS-Documentation/tree/xelatex
> >>> I also created "vagrant" branch to use Debian Wheezy 7.5 x64 image on
> >>> my MacOSX note PC.
> >>> About package lists for the image, please see the following
> >>> "bootstrap.sh".
> >>> == [vagrant] ==
> >>> branch root: https://github.com/sanak/QGIS-Documentation/tree/vagrant
> >>> bootstrap.sh:
> >>> I wrote that I will try also Debian Squeeze environement in this
> weekend,
> >>> but I become busy with other tasks, so I set this status to pending
> for a
> >>> while.
> >>> Regards,
> >>> Ko
> >>> 2014-06-18 21:16 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
> >>> > Hi Richard, BJ Jang
> >>> > Thanks for confirmation.
> >>> > I just pushed yesterday code to my git repository "xelatex" branch.
> >>> > branch root:
> >>> > commit diff:
> https://github.com/sanak/QGIS-Documentation/commit/e9a02494547c5b8f7ed4581c57ee492cd9b4ecff
> >>> > I confirmed Ubuntu 12.04 (precise = Debian Squeeze) xeCJK package is
> >>> > too old (Version 2.3.10 (30-Sept-2009)),
> >>> > and that seems to be the cause of Korean space issue.
> >>> > It may also be possible to build xeCJK source by hand,
> >>> > but I am not so familiar with LaTeX .etc...
> >>> > Is there some plan about upgrading current documentation server to
> >>> > Debian Wheezy?
> >>> > Anyway, I will try to create Debian Squeeze/Wheezy environment from
> >>> > scratch by Vagrant,
> >>> > and check it again in this weekend, because now I am testing only on
> >>> > Ubuntu 12.04 (precise).
> >>> > Thanks,
> >>> > 2014-06-18 20:21 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
> >>> >> On 17-06-14 14:50, Ko Nagase wrote:
> >>> >>> So, please check that your current "source/i18n/ko/conf.py"
> includes
> >>> >>> both original "source/conf.py"
> >>> >>> and extra "source/i18n/ko/conf.py.diff" contents.
> >>> >> Thanks for the hints.
> >>> >> I added this piece of config in the normal source.conf file, but do
> not
> >>> >> get better results then the other pdf without.
> >>> >> It is not clear to me if this is because of my own setup (missing
> >>> >> essential korean fonts or packages) or if I'm doing something else
> >>> >> wrong.
> >>> >> BJ Jang: are you able to build the Korean pdf yourself?
> >>> >> Any help is appreciated
> >>> >> Regards,
> >>> > Ko Nagase (長瀬 興)
> >>> > Georepublic Japan
> >>> > mail: nagase at georepublic.co.jp
> >>> > web: http://georepublic.co.jp
> >>> Ko Nagase (長瀬 興)
> >>> Georepublic Japan
> >> Open Source GIS Technical Manager / e-Cartographer
> >> BJ Jang
> >> Gaia3D Inc,
> > Ko Nagase (長瀬 興)
> > Georepublic Japan
> Ko Nagase (長瀬 興)
> Georepublic Japan
BJ Jang
*Gaia3D Inc,*
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20140719/d281f828/attachment-0001.html>
More information about the Qgis-tr
