[Qgis-tr] Translation of interface HTML help strings, do I need to keep all the breaklines?
Eduardo Gonzalez
eg at gismood.com
Mon Jun 16 06:42:32 PDT 2014
I found the same situation and decided to remove them... I thought that
they were unnitentioned break lines since as Alexandre says those are
ignored when creating the docs. I hope it is not a problem, for example
when the pdf documentation is created?
Eduardo
On Mon, Jun 16, 2014 at 4:36 PM, Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Hello Richard,
> thanks for your fast answer. I'm talking about normal linebreaks, the one
> you insert by pressing Enter.
> Some are in the middle of a sentence without a very clear idea why. After
> the translation it's not always possible to keep the linebreak between the
> same words.
> I think that probably those linebreak have no effect in the end result,
> but I just wanted to make sure.
> Here an example, I have part of a string like this:
> <p>A "delimited text file" contains data in which each record
>> starts on a new line, and ⏎
>> is split into fields by a delimiter such as a comma. ⏎
>> This type of file is commonly exported from spreadsheets (for example
>> CSV files) or databases. ⏎
>> Typically the first line of a delimited text file contains the names of
>> the fields. ⏎
>> </p>⏎
> And I'm not sure If there is any reason for keeping the break between
> "...new line, and " & "is split into..."
> thanks,
> Alexandre Neto
> On Mon, Jun 16, 2014 at 1:52 PM, Richard Duivenvoorde <richard at duif.net>
> wrote:
>> On 16-06-14 12:56, Alexandre Neto wrote:
>> > Hello all,
>> > Can anyone tell me how important is to keep the "break line characters"
>> > in the html help files during translation.
>> > In the end of a sentence I don't have any doubts, but sometimes in the
>> > middle it sounds weird to keep some breaklines, knowing that html should
>> > take care of that depending on the size of the users help window.
>> Hi Alexandre,
>> What do you mean by "break line characters", to you mean "<br/>" in
>> html? Or "\n" aka normal linebreaks in a string?
>> Because I think the second one are indeed ignored IF the text area will
>> become html (not always used).
>> In the first case I think the only way to know is to have a look into
>> the dialog/widget that the text is part of. I could think about an
>> option that a dev wants to add some whitespace or newlines in between
>> two chunks of text.
>> Sorry I do not have a clearer answer, maybe somebody else can?
>> Maybe better ask this on the dev list, because those are the people who
>> write the actual source strings...
>> Regards,
>> Qgis-tr mailing list
>> Qgis-tr at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20140616/f2c4198c/attachment-0001.html>
More information about the Qgis-tr
