[Qgis-tr] huge string to translate
Werner Macho
werner.macho at gmail.com
Wed Oct 29 00:09:35 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
I assume it was just a small change in the source - the "old"
translation should still be there and selectable - so just take the
old one and adjust only the small changes .. but .. I am also still
searching for the change ;)
The real problem is that it is taken as ONE string :(
Hope these things will be solved with switching to online Documentation
kind regards
Werner
On 10/29/2014 06:40 AM, Raymond Nijssen wrote:
> How come this huuuuuge string has suddenly appeared in QGIS
> application (and in transifex for translation) so shortly for the
> 2.6 release???
> Raymond
> <h3>Delimited Text File Layer</h3>⏎ Loads and displays delimited
> text files⏎ <p>⏎ <a href="#re">Overview</a><br/>⏎ <a
> href="#creating">Creating a delimited text layer</a><br/>⏎ <a
> href="#csv">How the delimiter, quote, and escape characters
> work</a><br />⏎ <a href="#regexp">How regular expression delimiters
> work</a><br />⏎ <a href="#wkt">How WKT text is interpreted</a><br
> />⏎ <a href="#attributes">Attributes in delimited text files</a><br
> />⏎ <a href="#example">Example of a text file with X,Y point
> coordinates</a><br/>⏎ <a href="#wkt_example">Example of a text file
> with WKT geometries</a><br/>⏎ <a href="#python">Using delimited
> text layers in Python</a><br/>⏎ </p>⏎ ⏎ <h4><a
> name="re">Overview</a></h4>⏎ <p>A "delimited text file"
> contains data in which each record starts on a new line, and ⏎ is
> split into fields by a delimiter such as a comma. ⏎ This type of
> file is commonly exported from spreadsheets (for example CSV files)
> or databases. ⏎ Typically the first line of a delimited text file
> contains the names of the fields. ⏎ </p>⏎ <p>⏎ Delimited text files
> can be loaded into QGIS as a layer. ⏎ The records can be displayed
> spatially either as a point⏎ defined by X and Y coordinates, or
> using a Well Known Text (WKT) definition of a geometry which may⏎
> describe points, lines, and polygons of arbitrary complexity. The
> file can also be loaded as an attribute⏎ only table, which can then
> be joined to other tables in QGIS.⏎ </p>⏎ <p>⏎ In addition to the
> geometry definition the file can contain text, integer, and real
> number fields. By default ⏎ QGIS will choose the type of field
> based on its the non blank values of the field. If all can be
> interpreted⏎ as integer then the type will be integer, if all can
> be interpreted as real numbers then the type will⏎ be double,
> otherwise the type will be text.⏎ </p>⏎ <p>⏎ QGIS can also read the
> types from an OGR CSV driver compatible "csvt" file. ⏎
> This is a file alongside the data file, but with a "t"
> appended to the file name. ⏎ The file should just contain one line
> which lists the type of each field. ⏎ Valid types are
> "integer", "real", "string",
> "date", "time", and "datetime". The
> date, time, and datetime types are treated as strings in QGIS.⏎
> Each type may be followed by a width and precision, for example
> "real(10.4)".⏎ The list of types are separated by commas,
> regardless of the delimiter used in the data file. An⏎ example of a
> valid format file would be:⏎ </p>⏎ ⏎ <pre>⏎
> "integer","string","string(20)","real(20.4)"⏎
> </pre>⏎ ⏎ <h4><a name="creating">Creating a delimited text
> layer</a></h4>⏎ <p>Creating a delimited text layer involves
> choosing the data file, defining the format (how each record is
> to⏎ be split into fields), and defining the geometry is
> represented. ⏎ This is managed with the delimited text dialog as
> detailed below. ⏎ The dialog box displays a sample from the
> beginning of the file which shows how the format⏎ options have been
> applied.⏎ </p>⏎ <h5>Choosing the data file</h5>⏎ <p>Use the
> "Browse..." button to select the data file. Once the file
> is selected the⏎ layer name will automatically be populated based
> on the file name. The layer name is used to represent⏎ the data in
> the QGIS legend. ⏎ </p>⏎ <p>⏎ By default files are assumed to be
> encoded as UTF-8. However other file⏎ encodings can be selected.
> For example "System" uses the default encoding for the
> operating system. ⏎ It is safer to use an explicit coding if the
> QGIS project needs to be portable.⏎ </p>⏎ <h5>Specifying the file
> format</h5>⏎ <p>The file format can be one of⏎ <ul>⏎ <li>CSV file
> format. This is a format commonly used by spreadsheets, in which
> fields are delimited⏎ by a comma character, and quoted using a
> "(quote) character. Within quoted fields, a quote⏎ mark is
> entered as "".</li>⏎ <li>Selected delimiters. Each record
> is split into fields using one or more delimiter character.⏎ Quote
> characters are used for fields which may contain delimiters. Escape
> characters may be used ⏎ to treat the following character as a
> normal character (ie to include delimiter, quote, and ⏎ new line
> characters in text fields). The use of delimiter, quote, and escape
> characters is detailed <a href="#csv">below</a>.⏎ <li>Regular
> expression. Each line is split into fields using a "regular
> expression" delimiter.⏎ The use of regular expressions is
> details <a href="#regexp">below</a>.⏎ </ul>⏎ <h5>Record and field
> options</h5>⏎ <p>The following options affect the selection of
> records and fields from the data file</p>⏎ <ul>⏎ <li>Number of
> header lines to discard: used to ignore header lines at the
> beginning of the text file</li>⏎ <li>First record has fields names:
> if selected then the first record in the file (after the discarded
> lines) is interpreted as names of fields, rather than as a data
> record.</li>⏎ <li>Trim fields: if selected then leading and
> trailing whitespace characters will be removed from each field
> (except quoted fields). </li>⏎ <li>Discard empty fields: if
> selected then empty fields (after trimming) will be discard. This
> ⏎ affects the alignment of data into fields and is equivalent to
> treating consecutive delimiters as a ⏎ single delimiter. Quoted
> fields are never discarded.</li>⏎ <li>Decimal separator is comma:
> if selected then commas instead of points are used as the decimal
> separator in real numbers. For⏎ example <tt>-51,354</tt> is
> equivalent to -51.354.⏎ </li>⏎ </ul>⏎ <h5>Geometry
> definition</h5>⏎ <p>The geometry is can be define as one of</p>⏎
> <ul>⏎ <li>Point coordinates: each feature is represented as a point
> defined by X and Y coordinates.</li>⏎ <li>Well known text (WKT)
> geometry: each feature is represented as a well known text string,
> for example⏎ <tt>POINT(1.525622 51.20836)</tt>. See details of the
> <a href="#wkt">well known text</a> format.⏎ <li>No geometry
> (attribute only table): records will not be displayed on the map,
> but can be viewed⏎ in the attribute table and joined to other
> layers in QGIS</li>⏎ </ul>⏎ <p>For point coordinates the following
> options apply:</p>⏎ <ul>⏎ <li>X field: specifies the field
> containing the X coordinate</li>⏎ <li>Y field: specifies the field
> containing the Y coordinate</li>⏎ <li>DMS angles: if selected
> coordinates are represented as degrees/minutes/seconds⏎ or
> degrees/minutes. QGIS is quite permissive in its interpretation of
> degrees/minutes/seconds.⏎ A valid DMS coordinate will contain three
> numeric fields with an optional hemisphere prefix or suffix⏎ (N, E,
> or + are positive, S, W, or - are negative). Additional non numeric
> characters are ⏎ generally discarded. For example
> <tt>N41d54'01.54"</tt> is a valid coordinate.⏎ </li>⏎ </ul>⏎
> <p>For well known text geometry the following options apply:</p>⏎
> <ul>⏎ <li>Geometry field: the field containing the well known text
> definition.</li>⏎ <li>Geometry type: one of "Detect"
> (detect), "Point", "Line", or
> "Polygon".⏎ QGIS layers can only display one type of
> geometry feature (point, line, or polygon). This option selects⏎
> which geometry type is displayed in text files containing multiple
> geometry types. Records containing⏎ other geometry types are
> discarded. ⏎ If "Detect" is selected then the type of the
> first geometry in the file will be used.⏎ "Point"
> includes POINT and MULTIPOINT WKT types, "Line" includes
> LINESTRING and⏎ MULTLINESTRING WKT types, and "Polygon"
> includes POLYGON and MULTIPOLYGON WKT types.⏎ </ul>⏎ <h5>Layer
> settings</h5>⏎ <p>Layer settings control the way the layer is
> managed in QGIS. The options available are:</p>⏎ <ul>⏎ <li>Use
> spatial index. Create a spatial index to improve the performance of
> displaying and selecting spatial objects.⏎ This option may be
> useful for files larger than a few megabytes in size.</li>⏎ <li>Use
> subset index. Create an index if a subset of records is being used
> (either by explicitly setting a subset string ⏎ from the layer
> properties dialog, or an implicit subset of features for which the
> geometry is valid in files⏎ for which all not geometries are
> valid). The index will only be created when a subset is
> defined.</li>⏎ <li>Watch file. If this options is selected QGIS
> will watch the file for changes by other applications, and ⏎ reload
> the file when it is changed. The map will not be updated until
> refreshed by the user, but indexes and⏎ extents will be reloaded.
> This option should be selected if indexes are used and it is likely
> that another⏎ application will change the file. </li>⏎ </ul>⏎ ⏎
> <h4><a name="csv">How the delimiter, quote, and escape characters
> work</a></h4>⏎ <p>Records are split into fields using three
> character sets: ⏎ delimiter characters, quote characters, and
> escape characters. ⏎ Other characters in the record are considered
> as data, split into⏎ fields by delimiter characters. ⏎ Quote
> characters occur in pairs and cause the text between them to be
> treated as a data. Escape characters cause the character following
> them to be treated as data. ⏎ </p>⏎ <p>⏎ Quote and escape
> characters cannot be the same as delimiter characters - they⏎ will
> be ignored if they are. Escape characters can be the same as quote
> characters, but behave differently⏎ if they are.</p>⏎ <p>The
> delimiter characters are used to mark the end of each field. If
> more than one delimiter character⏎ is defined then any one of the
> characters can mark the end of a field. The quote and escape
> characters ⏎ can override the delimiter character, so that it is
> treated as a normal data character.</p>⏎ <p>Quote characters may be
> used to mark the beginning and end of quoted fields. Quoted fields
> can ⏎ contain delimiters and may span multiple lines in the text
> file. If a field is quoted then it must⏎ start and end with the
> same quote character. Quote characters cannot occur within a field
> unless they⏎ are escaped.</p>⏎ <p>Escape characters which are not
> quote characters force the following character to be treated as
> data. ⏎ (that is, to stop it being treated as a new line,
> delimiter, or quote character). ⏎ </p>⏎ <p>Escape characters that
> are also quote characters have much more limited effect. They only
> apply within quotes and only escape themselves. For example, if ⏎
> <tt>'</tt> is a quote and escape character, then the string⏎
> <tt>'Smith''s Creek'</tt> will represent the value
> Smith's Creek.⏎ </p>⏎ ⏎ ⏎ <h4><a name="regexp">How regular
> expression delimiters work</a></h4>⏎ <p>Regular expressions are
> mini-language used to represent character patterns. There are many
> variations⏎ of regular expression syntax - QGIS uses the syntax
> provided by the <a
> href="http://qt-project.org/doc/qt-4.8/qregexp.html">QRegExp</a>
> class of the <a href="http://qt.digia.com">Qt</a> framework.</p>⏎
> <p>In a regular expression delimited file each line is treated as
> a record. Each match of the regular expression in the line is
> treated as the end of a field. ⏎ If the regular expression contains
> capture groups (eg <tt>(cat|dog)</tt>)⏎ then these are extracted as
> fields. ⏎ If this is not desired then use non-capturing groups (eg
> <tt>(?:cat|dog)</tt>).⏎ </p>⏎ <p>The regular expression is treated
> differently if it is anchored to the start of the line (that is,
> the pattern starts with <tt>^</tt>).⏎ In this case the regular
> expression is matched against each line. If the line does not match
> it is discarded⏎ as an invalid record. Each capture group in the
> expression is treated as a field. The regular expression⏎ is
> invalid if it does not have capture groups. As an example this can
> be used as a (somewhat ⏎ unintuitive) means of loading data with
> fixed width fields. For example the ⏎ expression⏎ <pre>⏎
> ^(.{5})(.{10})(.{20})(.{20})⏎ </pre>⏎ <p>will extract four fields
> of widths 5, 10, 20, and 20 characters from each line. ⏎ Lines less
> than 55 characters long will be discarded.⏎ </p>⏎ ⏎ ⏎ <h4><a
> name="wkt">How WKT text is interpreted</a></h4>⏎ <p>⏎ The delimited
> text layer recognizes the following ⏎ <a
> href="http://en.wikipedia.org/wiki/Well-known_text">well known
> text</a> types - ⏎ <tt>POINT</tt>, <tt>MULTIPOINT</tt>,
> <tt>LINESTRING</tt>, <tt>MULTILINESTRING</tt>, <tt>POLYGON</tt>,
> and <tt>MULTIPOLYGON</tt>. ⏎ It will accept geometries with⏎ a Z
> coordinate (eg <tt>POINT Z</tt>), a measure
> (<tt>POINT M</tt>), or both (<tt>POINT ZM</tt>).⏎ </p>⏎
> <p>⏎ It can also handle the PostGIS EWKT variation, in which the
> geometry is preceded by an spatial reference ⏎ system id (eg
> <tt>SRID=4326;POINT(175.3 41.2)</tt>), and a variant used by
> Informix in which the WKT is ⏎ preceded by an integer spatial
> reference id (eg <tt>1 POINT(175.3 41.2)</tt>).⏎ In both cases
> the SRID is ignored.⏎ </p>⏎ ⏎ ⏎ ⏎ <h4><a
> name="attributes">Attributes in delimited text files</a></h4> ⏎
> <p>Each record in the delimited text file is split into fields
> representing⏎ attributes of the record. Usually the attribute names
> are taken from the first⏎ data record in the file. However if this
> does not contain attribute names, then they will be named
> <tt>field_1</tt>, <tt>field_2</tt>, and so on. ⏎ Also if records
> have more fields than are defined in the header record then these⏎
> will be named <tt>field_#</tt>, where # is the field number (note
> that empty fields at the end of a record are ignored).⏎ QGIS may
> override ⏎ the names in the text file if they are numbers, or have
> names like <tt>field_#</tt>,⏎ or are duplicated.⏎ </p>⏎ <p>⏎ In
> addition to the attributes explicitly in the data file QGIS assigns
> a unique ⏎ feature id to each record which is the line number in
> the source file on which⏎ the record starts. ⏎ </p>⏎ <p>⏎ Each
> attribute also has a data type, one of string (text), integer, or
> real number.⏎ The data type is inferred from the content of the
> fields - if every non blank value⏎ is a valid integer then the type
> is integer, otherwise if it is a valid real⏎ number then the type
> is real, otherwise the type is string. Note that this is⏎ based on
> the content of the fields - quoting fields does not change the way
> they⏎ are interpreted.⏎ </p>⏎ ⏎ ⏎ <h4><a name="example">Example of
> a text file with X,Y point coordinates</a></h4> ⏎ <pre>⏎ X;Y;ELEV⏎
> -300120;7689960;13⏎ -654360;7562040;52⏎ 1640;7512840;3⏎ </pre>⏎
> <p>This file:</p>⏎ <ul>⏎ <li> Uses <b>;</b> as delimiter. Any
> character can be used to delimit the fields.</li>⏎ <li>The first
> row is the header row. It contains the field names X, Y and
> ELEV.</li>⏎ <li>The x coordinates are contained in the X
> field.</li>⏎ <li>The y coordinates are contained in the Y
> field.</li>⏎ </ul>⏎ <h4><a name="wkt_example">Example of a text
> file with WKT geometries</a></h4>⏎ <pre>⏎ id|wkt⏎
> 1|POINT(172.0702250 -43.6031036)⏎ 2|POINT(172.0702250
> -43.6031036)⏎ 3|POINT(172.1543206 -43.5731302)⏎ 4|POINT(171.9282585
> -43.5493308)⏎ 5|POINT(171.8827359 -43.5875983)⏎ </pre>⏎ <p>This
> file:</p>⏎ <ul>⏎ <li>Has two fields defined in the header row: id
> and wkt.⏎ <li>Uses <b>|</b> as a delimiter.</li>⏎ <li>Specifies
> each point using the WKT notation⏎ </ul>⏎ ⏎ <h4><a
> name="python">Using delimited text layers in Python</a></h4>⏎
> <p>Delimited text data sources can be creating from Python in a
> similar way to other vector layers.⏎ The pattern is:⏎ </p>⏎ <pre>⏎
> from PyQt4.QtCore import QUrl, QString⏎ from qgis.core import
> QgsVectorLayer, QgsMapLayerRegistry⏎ ⏎ # Define the data source⏎
> filename="test.csv"⏎ uri=QUrl.fromLocalFile(filename)⏎
> uri.addQueryItem("type","csv")⏎ uri.addQueryItem("delimiter","|")⏎
> uri.addQueryItem("wktField","wkt")⏎ # ... other delimited text
> parameters⏎ layer=QgsVectorLayer(QString(uri.toEncoded()),"Test
> CSV layer","delimitedtext")⏎ # Add the layer to the map⏎ if
> layer.isValid():⏎ QgsMapLayerRegistry.instance().addMapLayer( layer
> )⏎ </pre>⏎ <p>This could be used to load the second example file
> above.</p>⏎ <p>The configuration of the delimited text layer is
> defined by adding query items to the uri.⏎ The following options
> can be added⏎ </p>⏎ <ul>⏎ <li><tt>encoding=..</tt> defines the file
> encoding. The default is "UTF-8"</li>⏎
> <li><tt>type=(csv|regexp|whitespace)</tt> defines the delimiter
> type. Valid values are csv, ⏎ regexp, and whitespace (which is just
> a special case of regexp). The default is csv.</li>⏎
> <li><tt>delimiter=...</tt> defines the delimiters that will be used
> for csv formatted files, ⏎ or the regular expression for regexp
> formatted files. The default is , for CSV files. There is⏎ no
> default for regexp files.</li>⏎ <li><tt>quote=..</tt> (for csv
> files) defines the characters used to quote fields. The default is
> "</li>⏎ <li><tt>escape=..</tt> (for csv files) defines the
> characters used to escape the special meaning of the next
> character. The default is "</li>⏎ <li><tt>skipLines=#</tt>
> defines the number of lines to discard from the beginning of the
> file. The default is 0.</li>⏎ <li><tt>useHeader=(yes|no)</tt>
> defines whether the first data record contains the names of the
> data fields. The default is yes.</li>⏎
> <li><tt>trimFields=(yes|no)</tt> defines whether leading and
> trailing whitespace is to be removed from unquoted fields. The
> default is no.</li>⏎ <li><tt>maxFields=#</tt> defines the maximum
> number of fields that will be loaded from the file. ⏎ Additional
> fields in each record will be discarded. The default is 0 - include
> all fields.⏎ (This option is not available from the delimited text
> layer dialog box).</li>⏎ <li><tt>skipEmptyFields=(yes|no)</tt>
> defines whether empty unquoted fields will be discarded (applied
> after trimFields). The default is no.</li>⏎
> <li><tt>decimalPoint=.</tt> specifies an alternative character that
> may be used as a decimal point in numeric fields. The default is a
> point (full stop) character.</li>⏎ <li><tt>wktField=fieldname</tt>
> specifies the name or number (starting at 1) of the field
> containing a well known text geometry definition</li>⏎
> <li><tt>xField=fieldname</tt> specifies the name or number
> (starting at 1) of the field the X coordinate (only applies if
> wktField is not defined)</li>⏎ <li><tt>yField=fieldname</tt>
> specifies the name or number (starting at 1) of the field the Y
> coordinate (only applies if wktField is not defined)</li>⏎
> <li><tt>geomType=(auto|point|line|polygon|none)</tt> specifies type
> of geometry for wkt fields, or none to load the file as an
> attribute-only table. The default is auto.</li>⏎
> <li><tt>subset=expression</tt> specifies an expression used to
> identify a subset of the records that will be ⏎ used.</li>⏎
> <li><tt>crs=...</tt> specifies the coordinate system to use for
> the vector layer, in a format accepted by
> QgsCoordinateReferenceSystem.createFromString (for example
> "EPSG:4167"). If this is not ⏎ specified then a dialog
> box may request this information from the user⏎ when the layer is
> loaded (depending on QGIS CRS settings).</li>⏎
> <li><tt>subsetIndex=(yes|no)</tt> specifies whether the provider
> should build an index to define subset during the initial file
> scan. The index will apply both for explicitly defined subsets, and
> for the implicit subset of features for which the geometry
> definition is valid. By default the subset index is built if it is
> applicable.</li>⏎ <li><tt>spatialIndex=(yes|no)</tt> specifies
> whether the provider should build a spatial index during the
> initial file scan. By default the spatial index is not built.
> </li>⏎ <li><tt>watchFile=(yes|no)</tt> specifies whether the
> provider should use a file system watcher to monitor for changes to
> the file.</li>⏎ <li><tt>quiet=(yes|no)</tt> specifies whether
> errors encountered loading the layer are presented in a dialog box
> (they will be written to the QGIS log in any case). The default is
> no. This option is not available from the GUI</li>⏎ </ul>⏎ ⏎ ⏎
> _______________________________________________ Qgis-tr mailing
> list Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
iEYEARECAAYFAlRQkqwACgkQDAH1YiCxBgnZfwCeI+gezEyxk0/6AKRLFXrCYgJC
NSsAniyfg/myPXrDBXTAkFq97F4N9Rgr
=MJeC
-----END PGP SIGNATURE-----
More information about the Qgis-tr
