[Qgis-tr] [Qgis-developer] size of translations, use a distinct repo?
Werner Macho werner.macho at gmail.com
Wed Oct 29 12:49:58 PDT 2014
Hi!
I added the suggestion from jef and tried the new produced ts files in
linguist and transifex without any problems ..
So I decided to update everything again (with strings and transifex update) ..
ts files should now have no location inside any more ..
I hope that shrinks down the size from now on.
regards
Werner
On Wed, Oct 29, 2014 at 2:56 PM, Stott, James <fmrojst at fylkesmannen.no> wrote:
> As a slight side point, according to transifex it looks like we could have 13 fully translated languages for the GUI by the time 2.6 is released (13 languages are on 99% or more). 15 languages are over 95%. This is excellent news.
> Is it something we should publise, maybe add to the visual changelog?
> -----Opprinnelig melding-----
> Fra: qgis-tr-bounces at lists.osgeo.org [mailto:qgis-tr-bounces at lists.osgeo.org] På vegne av Werner Macho
> Sendt: 29. oktober 2014 14:15
> Til: Denis Rouzaud
> Kopi: QGIS Translation Discussions; qgis-developer
> Emne: Re: [Qgis-tr] [Qgis-developer] size of translations, use a distinct repo?
> hmm - ok ..
> Then I am going to give it a try without location and see if there are any problems with transifex or linguist ..
> If not - I also think that way is perfect ..
> regards
> Werner
> On Wed, Oct 29, 2014 at 2:11 PM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>> On 29.10.2014 14:06, Werner Macho wrote:
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> Good idea,
>>> if its really translation that causes the growth we should do
>>> everything to avoid that.
>> As Jurgen noticed, there are some useless changes in the ts files:
>>      <message>
>> -        <location filename="../src/core/qgscontexthelp_texts.cpp"
>> line="327"/>
>> +        <location filename="../src/core/qgscontexthelp_texts.cpp"
>> line="319"/>
>> if there are lines removed/added in the source file, this will cause
>> changes in the translation file.
>> Jurgen suggested to remove these tags "location filename" which would
>> improve a lot.
>>> Is there any way to "shrink" the already existing repo?
>>> At one point I thought about zipping the ts files - but if there is a
>>> better way .. good!
>>> I always wondered why the whole translations file has to be changed
>>> whenever there are only some small changes ..
>>> moving the translation in it's own github repository: hmm - I don't
>>> know if thats easily possible.. but I am also willing to try it if it
>>> helps the source code to stay clean.
>> I don't see any reason why it wouldn't be possible.
>> git submodules would be pretty useful for this matter.
>>> But again - anyway to shrink the already existing source code?
>> As far as I know, you can't shrink existing repo without destroying
>> the history.
>>> I don't mind about loosing track of translation changes.
>>> regards
>>> Werner
>>> On 10/29/2014 12:15 PM, Jürgen E. Fischer wrote:
>>>> Hi Denis,
>>>> On Wed, 29. Oct 2014 at 11:08:16 +0100, Denis Rouzaud wrote:
>>>>> Any thoughts?
>>>> I guess this is just due to the "location filename" stuff.  That
>>>> often causes massive change in the ts files, because lines were
>>>> added or removed from the source files - even if there isn't even a
>>>> changed translation.
>>>> I think that is not used at all for transifex and it's not that
>>>> important to have in linguist either.
>>>> So instead of inventing something new, all it takes might be to add
>>>> "-locations none" to our lupdate call, reduce the size of the .ts
>>>> files a lot (in one huge commit) and avoid useless tracking of
>>>> location changes in the future.
>>>> Objections?
>>>> Jürgen
>>>> _______________________________________________ Qgis-tr mailing list
>>>> Qgis-tr at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-tr
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v1.4.15 (GNU/Linux)
>>> iEYEARECAAYFAlRQ5k8ACgkQDAH1YiCxBgn7TQCeKllHCgzKm1Jn2iRT6iwPXkPd
>>> qmsAnjjWeXZySoZX9WQYf82w4s64s2ql
>>> =AGCZ
>>> -----END PGP SIGNATURE-----
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the Qgis-tr mailing list
