[Qgis-tr] Transifex: pros and cons
Richard Duivenvoorde
richard at duif.net
Mon Mar 23 03:25:48 PDT 2015
On 23-03-15 10:02, Werner Macho wrote:
> Hi all!
> I'm going to do some tests about the best way howto deal with that.
> IIRC you can download the ts file - rename it - copy it to the place
> in the source tree - translate it - rename it back to what it was
> while downloading and upload it again.
> (though not tested yet)
Hi Werner,
the crux is the 'location'- tags in the ts xml, like:
<location
filename="../src/plugins/coordinate_capture/coordinatecapture.cpp"
line="96"/>
if you see these in your ts file you are able to see the dialogs in
linguist.
My guess is that transifex 'washes' these away when you upload/download
a ts file.
As you can see the latest 'de' ts file:
https://github.com/qgis/QGIS/blob/master/i18n/qgis_de.ts
compared to a historical (pre tx) ts file:
https://raw.githubusercontent.com/qgis/QGIS/071fa924bec6c79fd3019af169627150c9dbb12c/i18n/qgis_de.ts
you can see the 'location' tags are missing in the latest (from tx) file.
I do not think it is doable for transifex to keep those, so only way is
to create the ts files yourself (which is not trivial, have a look into
the history of the update_ts_files.sh in the scripts dir)
Regards,
More information about the Qgis-tr
