[Qgis-tr] Transifex: pros and cons
Junior Delaz
delazj at gmail.com
Mon Mar 23 03:36:48 PDT 2015
If I'm not wrong, those location infos were present in Transifex and helped
to understand the context of text till a discussion about the size of the
repo becoming heavy (
http://lists.osgeo.org/pipermail/qgis-developer/2014-October/035327.html)
2015-03-23 11:25 GMT+01:00 Richard Duivenvoorde <richard at duif.net>:
> On 23-03-15 10:02, Werner Macho wrote:
> > Hi all!
> > I'm going to do some tests about the best way howto deal with that.
> > IIRC you can download the ts file - rename it - copy it to the place
> > in the source tree - translate it - rename it back to what it was
> > while downloading and upload it again.
> > (though not tested yet)
> Hi Werner,
> the crux is the 'location'- tags in the ts xml, like:
> <location
> filename="../src/plugins/coordinate_capture/coordinatecapture.cpp"
> line="96"/>
> if you see these in your ts file you are able to see the dialogs in
> linguist.
> My guess is that transifex 'washes' these away when you upload/download
> a ts file.
> As you can see the latest 'de' ts file:
> https://github.com/qgis/QGIS/blob/master/i18n/qgis_de.ts
> compared to a historical (pre tx) ts file:
> https://raw.githubusercontent.com/qgis/QGIS/071fa924bec6c79fd3019af169627150c9dbb12c/i18n/qgis_de.ts
> you can see the 'location' tags are missing in the latest (from tx) file.
> I do not think it is doable for transifex to keep those, so only way is
> to create the ts files yourself (which is not trivial, have a look into
> the history of the update_ts_files.sh in the scripts dir)
> Regards,
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20150323/762d182a/attachment.html>
More information about the Qgis-tr
