[Qgis-tr] Transifex: pros and cons
Richard Duivenvoorde richard at duif.net
Mon Mar 23 08:16:28 PDT 2015
On 23-03-15 15:29, Jürgen E. Fischer wrote:
> Hi Richard,
> On Mon, 23. Mar 2015 at 11:25:48 +0100, Richard Duivenvoorde wrote:
>> My guess is that transifex 'washes' these away when you upload/download
>> a ts file.
> No, we did.   Before we did the full switch to transifex, we first removed
> the location stuff from the ts files, because that was the main contributor
> to the high volume of changes in the translations - not because strings
> changed, but just because the line numbers changed.
> I switch from lupdate -locations none to lupdate -locations absolute so pushed
> the translations again.
Ah, ok. Thanks for clearing that up.
Let's have a look into the downloaded ts files then after the next
rebuild/upload and see if those locations are still in there after the
TX-roundtrip ....
If I'm correct we also do not push everyday to Github anymore did we? So
the 'high volume' changes were not so much a (github) problem anymore?
Regards,
More information about the Qgis-tr mailing list
