[Qgis-tr] Transifex: pros and cons
Werner Macho werner.macho at gmail.com
Mon Mar 23 08:22:06 PDT 2015
Hi Richard,
A push to github is now only done right in front of branching a new version.
So this should not be a github/space problem anymore.
Everything is now taking place on transifex.
And thanks to jef for doing the changes.
Hope this will work now for everyone and brings back the visual
editing possibility.
regards
Werner
On Mon, Mar 23, 2015 at 4:16 PM, Richard Duivenvoorde <richard at duif.net> wrote:
> On 23-03-15 15:29, Jürgen E. Fischer wrote:
>> Hi Richard,
>> On Mon, 23. Mar 2015 at 11:25:48 +0100, Richard Duivenvoorde wrote:
>>> My guess is that transifex 'washes' these away when you upload/download
>>> a ts file.
>> No, we did.   Before we did the full switch to transifex, we first removed
>> the location stuff from the ts files, because that was the main contributor
>> to the high volume of changes in the translations - not because strings
>> changed, but just because the line numbers changed.
>> I switch from lupdate -locations none to lupdate -locations absolute so pushed
>> the translations again.
> Ah, ok. Thanks for clearing that up.
> Let's have a look into the downloaded ts files then after the next
> rebuild/upload and see if those locations are still in there after the
> TX-roundtrip ....
> If I'm correct we also do not push everyday to Github anymore did we? So
> the 'high volume' changes were not so much a (github) problem anymore?
> Regards,
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
