[Qgis-tr] Are Transifex translations going anywhere?
    Werner Macho
    werner.macho at gmail.com
    Wed Apr 20 01:44:20 PDT 2016
Hi Carlos,
"tx" is a python module - you can install it either with your
distibutions package management system - or with pip.
The module is called "transifex" so it is either something like
python-transifex or python3-transifex - or you do a "pip install
transifex-client"
See: http://docs.transifex.com/client/setup/
Hope this helps
regards
Werner
On Wed, Apr 20, 2016 at 9:08 AM, Carlos Dávila <cdavilam at orangecorreo.es> wrote:
> Transifex Webtranslation page for QGIS is on https://www.transifex.com/qgis/
>> On 20-04-16 00:16, Jürgen E. Fischer wrote:
>>> Hi Carlos,
>>> On Tue, 19. Apr 2016 at 18:06:14 +0200, Carlos Dávila wrote:
>>>> In the last days I've been working on the Spanish translation of
>>>> QGIS Desktop on Transifex, but I don't see my changes neither in
>>>> master nor in 2.14 branch of github. Is there something broken in
>>>> the process of updating translations?
>>> No.  Translations are pulled in on release.  You can run
>>> scripts/pull_ts.sh to
>>> pull translations from transifex into local builds (like it's done in the
>>> nightlies).
>> So (see frontpage right top of qgis.org): next point release 2.14.2
>> (2.8.9??) will be 29th of april, THEN you should see the fresh
>> translations.
>> And as Jürgen says: if you install QGIS via osgeo4w (if on Windows) it
>> is easy to check the nightlies every day. And if you are on Linux:
>> really it is not as difficult as it looks to compile from source...
>> Regards,
>> Richard
> I usually compile QGIS from source on debian Linux to test translations. In
> the past it wasn't necessary to manually pull translations, they were
> updated with the rest of the code. I've tried scripts/pull_ts.sh, but first
> I had to change pylupdate4 by pylupdate5 and next "tx not found" error stops
> the script. Could you point me to the package containing tx? I could not
> find it.
> QGIS-Translators mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr
