[Qgis-tr] Typo in qgis-application .ts-file
Sveinn í Felli sv1 at fellsnet.is
Mon Nov 14 00:30:38 PST 2016
Þann fös 11.nóv 2016 17:55, skrifaði DelazJ:
> Werner, Thanks for the merge.
> I'm not sure we should backport this fix as it has already been translated
> as is by other languages. Backporting it will break those translations and
> this will require more work from the whole community.
Agree, this is already translated 'as-is' in lot of languages and won't
hurt the end users.
But the day will come, when someone proposes to substitute all the
triple-points [...] with a proper typographical ellipsis […]. Then we'd
better have some mechanism in place to make such substitution without
fuzzying all the translations. I know, because of other software
projects I'm involved in…
Sveinn
> 2016-11-11 18:37 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
>> Transifex Webtranslation page for QGIS is on https://www.transifex.com/
>> qgis/
>> Sorry for coming back on this such late but I was on the road..
>> Yes it is a matter of yource - and the patch is already accepted -
>> thanks for that.
>> translations sources should be updated automatically ..
>> Now we could also think about backporting it to 2.14 and 2.18 - but on
>> the other hand - translation is always concentrating on master ..
>> kind regards
>> Werner
>> qgis/
>>> Yes,
>>> You're right, I read again your first message and it's not a matter of
>>> translation but of source code indeed. I proposed a fix at
>>> https://github.com/qgis/QGIS/pull/3753 so no need to report a bug, yet.
>>> Thanks for your report.
>>> 2016-11-11 17:29 GMT+01:00 Sveinn í Felli <sv1 at fellsnet.is
>>> <mailto:sv1 at fellsnet.is>>:
>>>     https://www.transifex.com/qgis/ <https://www.transifex.com/qgis/>
>>>     Thanks a lot;
>>>     Þann fös 11.nóv 2016 11:13, skrifaði DelazJ:
>>>         Hi,
>>>         2016-11-10 9:09 GMT+01:00 Sveinn í Felli <sv1 at fellsnet.is
>>>             Hi,
>>>             I'm new on this list, so excuse me if there is another
>>>             procedure for
>>>             reporting source text errors. But first:
>>>             In my qgis-application_is.ts file there is the message
>>>             "Barscale Options"
>>>             in between other messages about "Scalebar" (approx. line #
>>>             28845):
>>>                 <message>
>>>                     <source>Scalebar segment size mode</source>
>>>                     <translation type="unfinished"></translation>
>>>                 </message>
>>>             </context>
>>>             <context>
>>>                 <name>QgsComposerScaleBarWidgetBase</name>
>>>                 <message>
>>>                     <source>Barscale Options</source>
>>>                     <translation>Valkostir kvarðastiku</translation>
>>>                 </message>
>>>                 <message>
>>>                     <source>Scalebar</source>
>>>             Is this an error ?
>>>             Should "barscale" be "scalebar" ?
>>>     Investigating a bit the other translations (es, fr, de) on GitHub,
>>>     it seems that most translators treat "barscale" the same as
>>>     "scalebar". So I'll do the same.
>>>     Nevertheless, to me such discrepancies seem like a bug, which I will
>>>     report in the bugtracker (hopefully soon).
>>>             I've seen some other errors and imprecisions in the source
>>>             text, apart
>>>             from reporting a bug, is there another way to
>>>             announce/submit potential
>>>             typos (for discussion first, then maybe submit a bug) ?
>>>             Yes, there are other ways to get things fixed:
>>>         - You can report it here or at hub.qgis.org
>>>         <http://hub.qgis.org> (tagged as translation) and
>>>         hope someone will do the job (note that as you began, it can be
>> an
>>>         opportunity to discuss things but I'm not sure it's the
>>>         best/quickest way)
>>>     Thanks, I think
>>>     <http://hub.qgis.org/projects/quantum-gis/issues?set_filter=
>> 1&tracker_id=1
>> 1&tracker_id=1>>
>>>     will be a good point of entry.
>>>         - Given that you have access to qgis-application_is.ts file I
>>>         assume you
>>>         already have an account on Transifex (otherwise, see
>>>         http://qgis.org/en/site/getinvolved/translate.html#
>> becoming-a-translator
>>>         <http://qgis.org/en/site/getinvolved/translate.html#
>> becoming-a-translator>).
>>>         You can directly fix strings from the web interface or download
>>>         the file
>>>         and fix it locally before pushing it to web (some notes about
>>>         this process
>>>         at
>>>         http://docs.qgis.org/2.14/en/docs/documentation_guidelines/
>> do_translations.html
>>>         <http://docs.qgis.org/2.14/en/docs/documentation_guidelines/
>> do_translations.html>
>>>         though a bit documentation oriented). Note that those fixes in
>>>         qgis-application_is.ts file will apply to QGIS3.0 as it's the
>>>         next release.
>>>         The Transifex webpage also offered a chat room which imho seems
>>>         a better
>>>         place to discuss icelandic translation stuffs
>>>     This is about the source code, not specifically Icelandic.
>>>         - If you want strings to be fixed in earlier maintained releases
>>>         (actually
>>>         2.14 and 2.18), you need to propose a pull request to the branch
>>>         in QGIS
>>>         repository (www.github.com/qgis/QGIS
>>>         <http://www.github.com/qgis/QGIS>). You'll need a github
>>>         account, fork
>>>         the QGIS repository and fixes a qgis_is.ts which should, if i'm
>>>         not wrong,
>>>         be in https://github.com/qgis/QGIS/tree/release-2_18/i18n
>>>         <https://github.com/qgis/QGIS/tree/release-2_18/i18n> (i
>>>         couldn't find
>>>         it, unless Icelandic has another code than "is").
>>>     This is really interesting, thanks again.
>>>     Or is it because they not
>>>         yet reach the minimum required to be pushed to desktop
>>>         application (they
>>>         are at 50%)?
>>>     Well, we are at 50% since yesterday when I pushed my last changes.
>>>     That is 50% of the number of strings, counting words it's nearer to
>>>     25% ;-(
>>>     There used to be a release for Icelandic some years ago (before
>>>     transifex?), you can get still that from conservative repositories
>>>     like Ubuntu which has QGIS v.2.0.1
>>>     But for QGIS v.2.18 and in the git.repo, Icelandic is absent.
>>>     I have to roll my own qgis_is.qm and drop it to the i18n-directory
>>>     to test my translations, works really well.
>>>     The primary interface and menus are done, secondary dialogs and most
>>>     configuration options are well advanced; expert options and popups
>>>     are ahead.
>>>         Hope that clarifies things and if it doesn't, please ask again,
>>>         Harrissou
>>>     Thanks a lot,
>>>     Sveinn í Felli
>>>         Best regards,
>>>             Sveinn í Felli
>>>             _______________________________________________
>>>             QGIS-Translators mailing list
>>>             Qgis-tr at lists.osgeo.org <mailto:Qgis-tr at lists.osgeo.org>
>>>             http://lists.osgeo.org/mailman/listinfo/qgis-tr
>>>             <http://lists.osgeo.org/mailman/listinfo/qgis-tr>
More information about the Qgis-tr mailing list
