[Qgis-tr] some questions
DelazJ
delazj at gmail.com
Wed Oct 4 01:50:56 PDT 2017
2017-10-04 0:52 GMT+02:00 Stefano Campus <skampus at gmail.com>:
> Transifex Webtranslation page for QGIS is on https://www.transifex.com/
> qgis/
> thank you all for replies.
> my organization will adopt the 2.18 version as soon as it becomes LTR and
> will hold it for at least a year.
Stefano, QGIS 2.18 is already LTR (since may) so no need to wait!
Regards,
Harrissou
Do you think it is correct to use the current version of transifex file.ts,
> transform it into the corresponding .qm version, through qt linguist, and
> use it as the italian version of version 2.18 LTR?
> I know there are so many more strings than master version but I think that
> strings that are not present in 2.18 are not a problem.
> Am I right?
> thank you again
> stefano
> 2017-10-01 11:01 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net>:
>> On 01-10-17 00:33, Jürgen E. Fischer wrote:
>> >> 3) Is there any chance of using the .ts file that you can download from
>> >> transifex in qgis and see "live" the results of our translation?
>> transifex
>> >> is very powerful but sometimes is very difficult to translate withow
>> the
>> >> knowledge of context.
>> > The nightlies of master pull them in on every build. But you can also
>> download
>> > the .ts file for use or translation.
>> If I am correct, you should be able to:
>> - download the .ts file from Transifex.com
>> - use Qt-Linguist to do further translations
>> - use command line OR Qt-Linguist to 'compile/release' your .ts file to
>> a .qm file
>> - if you put THAT .qm file on the right place in your QGIS installation,
>> QGIS will show you your fresh translations
>> - do not forget to copy your translations back to transifex, uploading
>> is also an option, but you will override any translations done while you
>> downloaded your sources.
>> HTH
>> Regards,
> QGIS-Translators mailing list
> Qgis-tr at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20171004/1eddf5d5/attachment.html>
More information about the Qgis-tr
