[Qgis-tr] Updating my desktop app with new translations
Sveinn í Felli sv1 at fellsnet.is
Tue Feb 20 00:45:00 PST 2018
Þann þri 20.feb 2018 08:08, skrifaði Ari Jolma:
> Hi,
> How do I update my QGIS desktop app with the latest translation? I do
> translations in transifex and use the QGIS from github master. However,
> the i18n files (*.ts) in github are quite old.
You can also update *your* copy of QGIS by opening the latest TS
translation file in Qt4 Linguist and choose 'File' --> 'Publish as...'
and write 'qgis_XX.qm' as filename (XX = language code). This compiles
the TS to a QM.
I think Transifex can also handle the conversion, you just choose to
'Download for use'.
Then you move/copy the QM-file over to the installation folder (as
root/admin), in Linux this would be /usr/share/qgis/i18n, don't know
about Windows.
Start QGIS in your locale, and voilá...
Note that the translation file should correspond to the exact version of
your QGIS-setup; translation strings do move and change between versions.
Best regards,
Sveinn í Felli
More information about the Qgis-tr mailing list
