[Qgis-tr] Issue while uploading translations made with QtLinguist to Transifex
Werner Macho
werner.macho at gmail.com
Wed Oct 3 04:30:24 PDT 2018
Hi Tomasz,
Thats exactly why the translation on transifex is the prefered one.
If you really have to check out the *.ts file you should upload it again as
soon as possible.
The consistency with more people working on the project can only be
guaranteed when working inside transifex.
Checking out the ts should only be an exception to the normal workflow (or
you coordinate with the other translators).
The checkout and upload is fully managed by transifex so there is less we
can do about that.
regards
Werner
On Wed, Oct 3, 2018 at 12:19 PM rychlicki.tomasz at gmail.com <
rychlicki.tomasz at gmail.com> wrote:
> Transifex Webtranslation page for QGIS is on
> https://www.transifex.com/qgis/
> There is also something that imho needs to be changed.
> If I take a TS to translate from Transifex, edit this TS and upload it to
> Transifex after certain amount of time it will roll back (overwrite)
> changes that someone might do during the period between mine downloading
> and uplading TS from/to Transifex.
> Is there a possibility to add a check of translated strings during upload
> if they are newer than stored in Transifex and update them only if they
> are? In the state that we have now it's highly possible to overwrite
> someone's work and throw it away.
> Tomasz Rychlicki
> QGIS-Translators mailing list
> Qgis-tr at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20181003/f37eb622/attachment.html>
More information about the Qgis-tr
