[Qgis-tr] Original Transifex translation files
Stefano Campus skampus at gmail.com
Fri Oct 29 09:38:51 PDT 2021
Thank you very much for your clear explanation, Jurgen.
s.
Il giorno mar 26 ott 2021 alle ore 18:35 Jürgen E. Fischer <jef at norbit.de>
ha scritto:
> Transifex Webtranslation page for QGIS is on
> https://www.transifex.com/qgis/
> Hi Stefano,
> On Tue, 26. Oct 2021 at 17:10:22 +0200, Stefano Campus wrote:
> > Hi, I have seen that the new version of the GUI for QGIS 3.22 has been
> > uploaded to transifex.
> > The following versions are now available for translation and review:
> > qgis-application
> > release-3-16
> > release-3-20
> > release-3-22
> > Thanks to the features of Transifex, the Italian team continues to update
> > all versions of QGIS.
> > I wanted to ask you the courtesy to let us know when the older versions
> > will be removed from Tx, so that we can download the .ts file, transform
> it
> > into .qm and upload it with a Pull Request in the GitHub repository.
> Which github repository do you mean?  The qgis repo doesn't contain .qm
> files.
> Those are created from the .ts files that are in the repo on build.
> And the .ts files are updates from transifex on release already.  From the
> branches repo on point releases and into master on minor and major release
> just
> before the new release branch is created.  At that point a also a
> corresponding
> transifex branch is created.
> release-3-20 doesn't need to be updated anymore as there are no more
> builds of
> 3.20.  Any translation changes after it's last release are more or less
> useless (just like commits to the repo).
> I guess the feature to delete branches is still broken in the transifex
> interface and will still have to ask transifex support to delete it.
> Oh, I never tried to delete transifex branches with the client.  I'll check
> that first.  I that works, I could just delete the previous release's
> branch
> via tx just like creating the new one.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
> QGIS-Translators mailing list
> Qgis-tr at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20211029/026b2960/attachment.html>
More information about the Qgis-tr mailing list
